Nerf N-Strike Maverick O-Ring Replacement
  1. Nerf N-Strike Maverick O-Ring Replacement, Nerf N-Strike Maverick Teardown: step 1, image 1 of 1
    • The Redeemer. Looks badass with its rotating barrel, but it's going to get a whole lot more badasserer quite soon...
    • Reminds me of a gun from the Fifth Element.
    Ask FixBot
  2. Nerf N-Strike Maverick O-Ring Replacement: step 2, image 1 of 1
    • First thing's first: let's remove some screws. All screws are conveniently Phillips, and all can be removed with a #0 or #00 size screwdriver.
    • Remove all ten Phillips screws.
    Ask FixBot
  3. Nerf N-Strike Maverick O-Ring Replacement: step 3, image 1 of 3 Nerf N-Strike Maverick O-Ring Replacement: step 3, image 2 of 3 Nerf N-Strike Maverick O-Ring Replacement: step 3, image 3 of 3
    • Another Phillips screw hides beneath the cocking mechanism thing. Remove that one as well.
    • The cocking mechanism's quite simple. A metal lever pulls back on the air plunger and compresses the large spring. Another small spring returns the slider back into its original position once it's done doing the dirty business..
    Ask FixBot
  4. Nerf N-Strike Maverick O-Ring Replacement: step 4, image 1 of 2 Nerf N-Strike Maverick O-Ring Replacement: step 4, image 2 of 2
    • And just like that, the gun comes apart.
    • Visible in the top left corner is the large spring and air plunger.
    • I later opened the gun again and put a folded piece of paper in this area. It gave the gun a bit more "punch" when sending darts on their merry way.
    Ask FixBot
  5. Nerf N-Strike Maverick O-Ring Replacement: step 5, image 1 of 1
    • Gun tip. I foresee it being black in the future.
    Ask FixBot
  6. Nerf N-Strike Maverick O-Ring Replacement: step 6, image 1 of 2 Nerf N-Strike Maverick O-Ring Replacement: step 6, image 2 of 2
    • First comes out the air plunger. It lifts right up.
    • The barrel comes out next.
    Ask FixBot
  7. Nerf N-Strike Maverick O-Ring Replacement: step 7, image 1 of 2 Nerf N-Strike Maverick O-Ring Replacement: step 7, image 2 of 2
    • The trigger is held in place by a sole Phillips screw. It also has a small spring for that authentic handgun "springy" feeling...
    Ask FixBot
  8. Nerf N-Strike Maverick O-Ring Replacement: step 8, image 1 of 3 Nerf N-Strike Maverick O-Ring Replacement: step 8, image 2 of 3 Nerf N-Strike Maverick O-Ring Replacement: step 8, image 3 of 3
    • The trigger's spring also attaches via a Phillips screw. A couple of twists with the screwdriver and it comes right out.
    • The fancy rotator for the barrel is next. I assume that were the gun to break, this would be the part that fails. It's the most complex part of the gun.
    Ask FixBot
  9. Nerf N-Strike Maverick O-Ring Replacement: step 9, image 1 of 1
    • Looking down the gun's business end.
    • I didn't bother to take the barrel apart. I didn't feel that adventurous.
    Ask FixBot
  10. Nerf N-Strike Maverick O-Ring Replacement: step 10, image 1 of 1
    • Here it is -- the whole gun taken apart.
    • It's so easy to assemble, a child could do it. Maybe Nerf's motto is "From our kids to your kids"?
    • I sincerely hope Nerf products are manufactured in countries that have strict child labor laws. I in no way, shape, or form condone child labor.
    Ask FixBot
  11. Nerf N-Strike Maverick O-Ring Replacement: step 11, image 1 of 2 Nerf N-Strike Maverick O-Ring Replacement: step 11, image 2 of 2
    • The finished product.
    • I took the gun to work and shot these pictures under a better lighting/camera setup... A much better lighting/camera setup.
    Ask FixBot
  12. Nerf N-Strike Maverick O-Ring Replacement, The Beginning: step 12, image 1 of 1
    • Follow steps 1 through 4 of the Nerf N-Strike Maverick Teardown guide.
    Ask FixBot
  13. Nerf N-Strike Maverick O-Ring Replacement, Locate the Gasket: step 13, image 1 of 1
    • Locate the air plunger in the upper left hand corner of the opened nerf gun. Push back on the spring and carefully pull the plunger toward you to remove it.
    Ask FixBot
  14. Nerf N-Strike Maverick O-Ring Replacement, Locating the O-Ring: step 14, image 1 of 1
    • Once you have the air plunger removed, locate the O-Ring by pulling the two pieces of the air plunger apart.
    Ask FixBot
  15. Nerf N-Strike Maverick O-Ring Replacement, Removing the O-Ring: step 15, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the O-Ring from the top of the air plunger.
    Ask FixBot
  16. Nerf N-Strike Maverick O-Ring Replacement: step 16, image 1 of 1
    • Follow steps 1 through 4 of the "Nerf N-Strike Maverick Teardown" guide in reverse order to reassemble the gun.
    Ask FixBot
tanika gorham
19 Reputation
1 Guide authored
1 Guide Comment
What size o ring did you use?
Jeffrey Wilder - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 49
All Time: 7,373
