Nerf N-Strike Firestrike Firing Trigger Replacement
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: step 1, image 1 of 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
    Ask FixBot
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: step 2, image 1 of 2 Nerf N-Strike Firestrike Firing Trigger Replacement: step 2, image 2 of 2
    • Slide out the two AAA batteries using your fingers.
    Ask FixBot
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: step 3, image 1 of 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
    Ask FixBot
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: step 4, image 1 of 2 Nerf N-Strike Firestrike Firing Trigger Replacement: step 4, image 2 of 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
    Ask FixBot
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: step 5, image 1 of 2 Nerf N-Strike Firestrike Firing Trigger Replacement: step 5, image 2 of 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
    Ask FixBot
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: step 6, image 1 of 2 Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: step 6, image 2 of 2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
    Ask FixBot
6 other people completed this guide.
Jong Wan Kim
488 Reputation
2 Guides authored
Cal Poly, Team 15-6, Amido Spring 2015 Member of Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 26
All Time: 3,555
