Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
5 other people completed this guide.
5 Guide Comments
Where can I buy a replacement spring?
you can get a replacement or an upgrade spring at the website www.nfstrike.com
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
I opened it and some parts fell out and I don't know where they belong:
A small, orange plastic rectangle. About 12x8x2mm in diameter. One side has two ridges in the middle sticking up, the other side has 4 nobs on the corners and circle protrusion.
what is it, where does it belong?
