Nerf N-Strike Elite Retaliator Case Disassembly
Views: 39K
View statistics:
Past 24 Hours:
7
Past 7 Days:
49
Past 30 Days:
171
All Time:
39,259
Comments: 24
9 comments on steps, 15 guide comments.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Moving components in your blaster can be accessed by removing the outer casing. This guide shows how to access these inner components.
Tools
    1. Nerf N-Strike Elite Retaliator Case Disassembly, Case Disassembly: step 1, image 1 of 1
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      Ask FixBot
    2. Nerf N-Strike Elite Retaliator Case Disassembly: step 2, image 1 of 1
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      Ask FixBot
    3. Nerf N-Strike Elite Retaliator Case Disassembly: step 3, image 1 of 1
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      Ask FixBot
    4. Nerf N-Strike Elite Retaliator Case Disassembly: step 4, image 1 of 2 Nerf N-Strike Elite Retaliator Case Disassembly: step 4, image 2 of 2
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      Ask FixBot
    5. Nerf N-Strike Elite Retaliator Case Disassembly: step 5, image 1 of 2 Nerf N-Strike Elite Retaliator Case Disassembly: step 5, image 2 of 2
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      Ask FixBot
Finish Line
29 other people completed this guide.
ericharman
1,440 Reputation
5 Guides authored
15 Guide Comments
How do I clean the slider track?
devinwhaley - Reply Share
you probably should not do that. i think its oily for a reason.
one smol birb - Reply Share
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay - Reply Share
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - Reply Share
Leave the screws in the casing
Ewan Dority - Reply Share
Past 24 Hours: 7
Past 7 Days: 49
Past 30 Days: 171
All Time: 39,259
