Nerf N-Strike Elite Retaliator Barrel Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
31
Past 30 Days:
121
All Time:
12,694
Comments: 1
1 comment on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
A damaged or obstructed barrel can greatly hinder your blaster’s performance. Follow the procedure to clean or replace the barrel.
Modifying your blaster is not advised and may void the manufacturer’s warranty in certain states.
This blaster is equipped with a rifled barrel for maximum performance.
Tools
    1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: step 1, image 1 of 1
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      Ask FixBot
    2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: step 2, image 1 of 1
      • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
      • This may require more force than anticipated.
      Ask FixBot
    3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: step 3, image 1 of 1
      • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
      Ask FixBot
    4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: step 4, image 1 of 1
      • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
      • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
      Ask FixBot
    5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: step 5, image 1 of 1
      • Remove the orange barrel from the assembly.
      Ask FixBot
7 other people completed this guide.
ericharman
1,440 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 121
All Time: 12,694
