Nerf N-Strike Elite Hail-Fire Trigger Replacement
    1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: step 1, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: step 1, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: step 1, image 3 of 3
      • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
      • Remove the two 9.0 mm Phillips screws securing the battery compartment.
      • Slide the battery compartment out.
      Ask FixBot
    2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 2, image 1 of 1
      • Remove the five 9.0 mm Phillips screws securing the trigger.
      Ask FixBot
    3. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 3, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 3, image 2 of 2
      • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
      • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
      Ask FixBot
    4. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 4, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 4, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 4, image 3 of 3
      • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
      • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
      Ask FixBot
    5. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 5, image 1 of 1
      • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
      Ask FixBot
    6. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 6, image 1 of 1
      • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
      Ask FixBot
    7. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 7, image 1 of 1
      • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
      • Remove the single 7.0 mm Phillips screw below the barrel.
      • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
      Ask FixBot
    8. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 8, image 1 of 1
      • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
      Ask FixBot
    9. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 9, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 9, image 2 of 2
      • Remove the two 9.0 mm Phillips screws holding together the handle.
      • Remove the plastic cover of the handle.
      Ask FixBot
    10. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 10, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 10, image 2 of 2
      • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
      • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
      Ask FixBot
    11. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 11, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 11, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 11, image 3 of 3
      • Pull one end of the handle away from the orange latch.
      • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
      Ask FixBot
    12. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 12, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 12, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 12, image 3 of 3
      • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
      • Completely remove the left shell from the rest of the Nerf Gun.
      Ask FixBot
    1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: step 13, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: step 13, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: step 13, image 3 of 3
      • Remove the cartridge support.
      Ask FixBot
    2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 14, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 14, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 14, image 3 of 3
      • Remove the handle crank.
      Ask FixBot
    3. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 15, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 15, image 2 of 2
      • Remove the clear plastic barrel cover.
      Ask FixBot
    4. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 16, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 16, image 2 of 2
      • Remove the firing pin.
      Ask FixBot
    1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Right Shell: step 17, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Right Shell: step 17, image 2 of 2
      • Lift the trigger mechanism out of the shell.
      • You cannot fully remove the trigger mechanism just yet. However taking it out of the shell helps in later steps.
      Ask FixBot
    2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 18, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 18, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 18, image 3 of 3
      • Remove the two 9.0 mm Phillips screws.
      Ask FixBot
    3. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 19, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 19, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 19, image 3 of 3
      • To remove the motor and trigger mechanism you have to detach these two wires which are glued to the shell.
      • Hold close to the wire and pull upward slowly.
      • If you pull too quickly you can potentially damage the wire.
      Ask FixBot
    4. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 20, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 20, image 2 of 2
      • Once all the pieces are removed the right shell should be fully accessible.
      Ask FixBot
    1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: step 21, image 1 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: step 21, image 2 of 3 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: step 21, image 3 of 3
      • Remove the single 9.0 mm Phillips screw.
      Ask FixBot
    2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 22, image 1 of 2 Nerf N-Strike Elite Hail-Fire Trigger Replacement: step 22, image 2 of 2
      • Locate the orange bar protruding from the rest of the gun. You should see the spring hooked onto two ends.
      • Push the orange bar until the spring becomes loose.
      • The trigger should come loose right away.
      Ask FixBot
Chris
273 Reputation
2 Guides authored
Cal Poly, Team 13-13, Regan Winter 2014 Member of Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 99
All Time: 3,027
