Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement
  1. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: step 1, image 1 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: step 1, image 2 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: step 1, image 3 of 3
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
    Ask FixBot
  2. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 2, image 1 of 1
    • Remove the five 9.0 mm Phillips screws securing the trigger.
    Ask FixBot
  3. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 3, image 1 of 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 3, image 2 of 2
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
    Ask FixBot
  4. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 4, image 1 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 4, image 2 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 4, image 3 of 3
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
    Ask FixBot
  5. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 5, image 1 of 1
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
    Ask FixBot
  6. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 6, image 1 of 1
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
    Ask FixBot
  7. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 7, image 1 of 1
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
    Ask FixBot
  8. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 8, image 1 of 1
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
    Ask FixBot
  9. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 9, image 1 of 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 9, image 2 of 2
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
    Ask FixBot
  10. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 10, image 1 of 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 10, image 2 of 2
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
    Ask FixBot
  11. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 11, image 1 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 11, image 2 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 11, image 3 of 3
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
    Ask FixBot
  12. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 12, image 1 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 12, image 2 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 12, image 3 of 3
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
    Ask FixBot
  13. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: step 13, image 1 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: step 13, image 2 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: step 13, image 3 of 3
    • Remove the cartridge support.
    Ask FixBot
  14. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 14, image 1 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 14, image 2 of 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 14, image 3 of 3
    • Remove the handle crank.
    Ask FixBot
  15. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 15, image 1 of 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 15, image 2 of 2
    • Remove the clear plastic barrel cover.
    Ask FixBot
  16. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 16, image 1 of 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: step 16, image 2 of 2
    • Remove the firing pin.
    Ask FixBot
sage
301 Reputation
3 Guides authored
Cal Poly, Team 13-13, Regan Winter 2014 Member of Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 66
All Time: 1,621
