Up to 20% off select tools
Nerf Mega Magnus Spring Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
136
All Time:
4,473
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nerf Mega Magnus Spring Replacement, Spring: step 1, image 1 of 3 Nerf Mega Magnus Spring Replacement, Spring: step 1, image 2 of 3 Nerf Mega Magnus Spring Replacement, Spring: step 1, image 3 of 3
      • Start by removing the (4) exterior Phillips screws from the shell of the gun with a #1 Phillips Screwdriver.
      Ask FixBot
    2. Nerf Mega Magnus Spring Replacement: step 2, image 1 of 2 Nerf Mega Magnus Spring Replacement: step 2, image 2 of 2
      • Pulling upward from the rest of the shell, carefully remove the half of the slide facing you.
      Ask FixBot
    3. Nerf Mega Magnus Spring Replacement: step 3, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 3, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 3, image 3 of 3
      • On the same side, remove all (9) screws from the body of the blaster as shown.
      Ask FixBot
    4. Nerf Mega Magnus Spring Replacement: step 4, image 1 of 2 Nerf Mega Magnus Spring Replacement: step 4, image 2 of 2
      • Lift up on the top half of the shell with deliberate force. This should reveal the internals.
      Ask FixBot
    5. Nerf Mega Magnus Spring Replacement: step 5, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 5, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 5, image 3 of 3
      • Remove the screws from the trigger mechanism and lift it upward
      Ask FixBot
    6. Nerf Mega Magnus Spring Replacement: step 6, image 1 of 2 Nerf Mega Magnus Spring Replacement: step 6, image 2 of 2
      • Locate the small grey piece under the plunger tube and remove the screw.
      Ask FixBot
    7. Nerf Mega Magnus Spring Replacement: step 7, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 7, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 7, image 3 of 3
      • Locate the screws on the return spring. Using a counterclockwise rotation, remove both of the screws.
      Ask FixBot
    8. Nerf Mega Magnus Spring Replacement: step 8, image 1 of 2 Nerf Mega Magnus Spring Replacement: step 8, image 2 of 2
      • Using a small tool, carefully remove the spring from its pegs.
      Ask FixBot
    9. Nerf Mega Magnus Spring Replacement: step 9, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 9, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 9, image 3 of 3
      • Locate the screws behind the dart pusher mechanism. Carefully remove each screw.
      Ask FixBot
    10. Nerf Mega Magnus Spring Replacement: step 10, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 10, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 10, image 3 of 3
      • Pull upwards on the dart pusher and spring to remove them.
      Ask FixBot
    11. Nerf Mega Magnus Spring Replacement: step 11, image 1 of 2 Nerf Mega Magnus Spring Replacement: step 11, image 2 of 2
      • Lift up on the magazine plate in order to remove it.
      Ask FixBot
    12. Nerf Mega Magnus Spring Replacement: step 12, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 12, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 12, image 3 of 3
      • Pull upward on the dart lip and it will lift off.
      Ask FixBot
    13. Nerf Mega Magnus Spring Replacement: step 13, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 13, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 13, image 3 of 3
      • Lift the left side of the plunger tube from its peg and the rest will slide off the spring peg.
      Ask FixBot
    14. Nerf Mega Magnus Spring Replacement: step 14, image 1 of 3 Nerf Mega Magnus Spring Replacement: step 14, image 2 of 3 Nerf Mega Magnus Spring Replacement: step 14, image 3 of 3
      • Slide the spring off its peg. If the spring is damaged, replace it.
      Ask FixBot
3 other people completed this guide.
Author
with
Averi Fletcher
147 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 136
All Time: 4,473
