Nerf Alpha Trooper CS-18 Plunger Replacement
    1. Nerf Alpha Trooper CS-18 Plunger Replacement, Plunger: step 1, image 1 of 1
      • It is important to group screws together by length to ensure proper reassembly.
      • Be sure that the device has been discharged and is unloaded before beginning the repair process.
      Ask FixBot
    2. Nerf Alpha Trooper CS-18 Plunger Replacement: step 2, image 1 of 3 Nerf Alpha Trooper CS-18 Plunger Replacement: step 2, image 2 of 3 Nerf Alpha Trooper CS-18 Plunger Replacement: step 2, image 3 of 3
      • Look at the rear of the rifle. Remove the two 10 mm Phillips head screws that hold the black cap to the rear of the rifle.
      • Gently remove the black cap.
      Ask FixBot
    3. Nerf Alpha Trooper CS-18 Plunger Replacement: step 3, image 1 of 2 Nerf Alpha Trooper CS-18 Plunger Replacement: step 3, image 2 of 2
      • Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
      • Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
      • Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
      • Be sure to keep track of which screws correspond to the correct holes.
      Ask FixBot
    4. Nerf Alpha Trooper CS-18 Plunger Replacement: step 4, image 1 of 3 Nerf Alpha Trooper CS-18 Plunger Replacement: step 4, image 2 of 3 Nerf Alpha Trooper CS-18 Plunger Replacement: step 4, image 3 of 3
      • Keeping the barrel in the same position as step 3, remove the fourteen 10 mm Phillips head screws from the body of the device.
      • With the device in the same position, remove the 4 remaining 5 mm Phillips head screws from the body of the device.
      • Screws vary in lengths. Be sure to keep track of which screws correspond to the correct holes.
      Ask FixBot
    5. Nerf Alpha Trooper CS-18 Plunger Replacement: step 5, image 1 of 3 Nerf Alpha Trooper CS-18 Plunger Replacement: step 5, image 2 of 3 Nerf Alpha Trooper CS-18 Plunger Replacement: step 5, image 3 of 3
      • Grip the cartridge insert, and pull the two halves of the device apart.
      • Warning! The firing spring is not fastened to the device. It and other small parts may fall out of the device when separating it.
      • If you are having difficulty separating the two halves of the device, use a spudger to pry the two halves apart.
      • Remove the access gate and barrel cover.
      Ask FixBot
    6. Nerf Alpha Trooper CS-18 Plunger Replacement: step 6, image 1 of 1
      • Now remove the main firing spring from the rear of the device by gently pulling it.
      Ask FixBot
    7. Nerf Alpha Trooper CS-18 Plunger Replacement: step 7, image 1 of 2 Nerf Alpha Trooper CS-18 Plunger Replacement: step 7, image 2 of 2
      • Slide the plunger lock back away from the device, then lift out towards yourself to remove.
      • Be careful not to lose the small spring on the top of the plunger lock.
      Ask FixBot
    8. Nerf Alpha Trooper CS-18 Plunger Replacement: step 8, image 1 of 1
      • Pull plunger away in the same motion as in step 7 with the plunger lock.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 62
All Time: 2,549
