Up to 20% off select tools
Neo3Do Back Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
81
All Time:
676
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The guide is the beginning of every other guide for the Neo3DO device. In order to access any of the other parts for repair or replacement, you need to remove the back panel. DO NOT attempt to remove the front screen, as it is part of the device case and removing it will damage the tablet.
Check all other guides you plan to follow and have all tools laid out in advance. Make sure your workspace is clean and clear of anything not needed for the replacement.
    1. Neo3Do Back Panel Replacement, Back Panel: step 1, image 1 of 3 Neo3Do Back Panel Replacement, Back Panel: step 1, image 2 of 3 Neo3Do Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Turn the Neo3DO face down so that the logo is facing toward you.
      • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
      Ask FixBot
    2. Neo3Do Back Panel Replacement: step 2, image 1 of 2 Neo3Do Back Panel Replacement: step 2, image 2 of 2
      • Gently pry the back panel upwards.
      • Ensure the tool does not slip into the device and damage the internals.
      Ask FixBot
    3. Neo3Do Back Panel Replacement: step 3, image 1 of 2 Neo3Do Back Panel Replacement: step 3, image 2 of 2
      • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
      Ask FixBot
    4. Neo3Do Back Panel Replacement: step 4, image 1 of 1
      • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
      • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
      Ask FixBot
Finish Line
Author
with
Michael Whitehead
201 Reputation
2 Guides authored
USF Tampa, Team 14-3, Eyestone Fall 2016 Member of USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 81
All Time: 676
