Necklace or Bracelet Clasp Replacement
  1. Necklace or Bracelet Clasp Replacement, Clasp: step 1, image 1 of 3 Necklace or Bracelet Clasp Replacement, Clasp: step 1, image 2 of 3 Necklace or Bracelet Clasp Replacement, Clasp: step 1, image 3 of 3
    • Using either a pair of needle nose pliers or a pair of round nose pliers, open the jump ring attached to the jewelry clasp by twisting the ring apart.
    Ask FixBot
  2. Necklace or Bracelet Clasp Replacement: step 2, image 1 of 2 Necklace or Bracelet Clasp Replacement: step 2, image 2 of 2
    • Slide off the broken clasp from the jump ring.
    Ask FixBot
  3. Necklace or Bracelet Clasp Replacement: step 3, image 1 of 1
    • Remove the jump ring.
    Ask FixBot
  4. Necklace or Bracelet Clasp Replacement: step 4, image 1 of 2 Necklace or Bracelet Clasp Replacement: step 4, image 2 of 2
    • Using a new jump ring, open it with the pliers and slide it into the necklace using the same pull-apart method.
    Ask FixBot
  5. Necklace or Bracelet Clasp Replacement: step 5, image 1 of 2 Necklace or Bracelet Clasp Replacement: step 5, image 2 of 2
    • Take the new clasp and slide it onto the new jump ring.
    Ask FixBot
  6. Necklace or Bracelet Clasp Replacement: step 6, image 1 of 1
    • Close the new jump ring.
    • If the jump ring does not completely close, use the pliers to squeeze the ring gently so the ends come together.
    Ask FixBot
  7. Necklace or Bracelet Clasp Replacement: step 7, image 1 of 2 Necklace or Bracelet Clasp Replacement: step 7, image 2 of 2
    • If you need to extend your necklace/bracelet, take the new jump rings, and open them with the pliers. Linking them one at a time with the same open/close procedure as previously demonstrated, add them to the opposite side of the new clasp.
    Ask FixBot
  8. Necklace or Bracelet Clasp Replacement: step 8, image 1 of 2 Necklace or Bracelet Clasp Replacement: step 8, image 2 of 2
    • Add on the non-clasp back piece to the new jump ring chain using same open/close process as previously demonstrated.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 74
All Time: 889
