Neato XV-21 Wheels Replacement
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: step 1, image 1 of 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: step 2, image 1 of 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: step 3, image 1 of 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: step 4, image 1 of 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: step 5, image 1 of 1
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: step 6, image 1 of 1
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: step 7, image 1 of 2 Neato XV-21 Wheels Replacement: step 7, image 2 of 2
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
3 other people completed this guide.
1 Guide Comment
Needs to Link to Parts List and a way to Order Parts.
Bill Price - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 52
All Time: 962
