Neato XV-21 Lidar Distance Sensor Replacement
    1. Neato XV-21 Lidar Distance Sensor Replacement, Back Panels of Neato XV-21: step 1, image 1 of 1
      • Flip the Neato on its back so the bottom is exposed
      • Unscrew the seven screws.
      Ask FixBot
    2. Neato XV-21 Lidar Distance Sensor Replacement: step 2, image 1 of 1
      • Lift the panels to reveal the batteries, brush and fan
      • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
      Ask FixBot
    3. Neato XV-21 Lidar Distance Sensor Replacement: step 3, image 1 of 1
      • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
      Ask FixBot
    1. Neato XV-21 Lidar Distance Sensor Replacement, Battery: step 4, image 1 of 1
      • Pinch and pull the white connector to disconnect the battery from the device
      • Failure to complete this step could cause electric shock or later complications
      • Lift and remove the battery from the cavity
      • If replacing the battery, make sure to use proper disposal methods.
      Ask FixBot
    1. Neato XV-21 Lidar Distance Sensor Replacement, Lidar Distance Sensor: step 5, image 1 of 1
      • Remove the 17 visible screws and the 2 covered/hidden screws near the battery compartments that connect the bottom to the top of the Neato robot.
      Ask FixBot
    2. Neato XV-21 Lidar Distance Sensor Replacement: step 6, image 1 of 1
      • Lift and separate the two pieces to give access to the Distance Sensor
      • There may be slight resistance during this step, make sure to lift the pieces straight rather than an angle. Lifting at an angle may cause pieces to catch, causing resistance
      Ask FixBot
    3. Neato XV-21 Lidar Distance Sensor Replacement: step 7, image 1 of 3 Neato XV-21 Lidar Distance Sensor Replacement: step 7, image 2 of 3 Neato XV-21 Lidar Distance Sensor Replacement: step 7, image 3 of 3
      • Remove the four screws on the lidar sensor.
      • After the wires are fully disconnected lift the motor away to reveal the motherboard
      • There should be little to no resistance during this step. Do not continue if there is resistance, this may damage the motherboard
      Ask FixBot
    4. Neato XV-21 Lidar Distance Sensor Replacement: step 8, image 1 of 1
      • Pinch and pull the white connectors indicated in the image, this will allow the top and bottom panels to fully seperate
      Ask FixBot
1 Guide Comment
Mine has a wire jumper that I can't remember where it goes. It appears to be an extension for the Lidar motor wires, but I can't say for sure if that's where it was when I took this apart over a year ago. I can't find anywhere else it might go.
were those common in these? or do know of anyplace else it might go?
Thanks!
Ralph Hipps - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 98
All Time: 3,502
