Neato XV-21 Fan Replacement
    1. Neato XV-21 Fan Replacement, Back Panels of Neato XV-21: step 1, image 1 of 1
      • Flip the Neato on its back so the bottom is exposed
      • Unscrew the seven screws.
      Ask FixBot
    2. Neato XV-21 Fan Replacement: step 2, image 1 of 1
      • Lift the panels to reveal the batteries, brush and fan
      • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
      Ask FixBot
    3. Neato XV-21 Fan Replacement: step 3, image 1 of 1
      • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
      Ask FixBot
    1. Neato XV-21 Fan Replacement, Battery: step 4, image 1 of 1
      • Pinch and pull the white connector to disconnect the battery from the device
      • Failure to complete this step could cause electric shock or later complications
      • Lift and remove the battery from the cavity
      • If replacing the battery, make sure to use proper disposal methods.
      Ask FixBot
    1. Neato XV-21 Fan Replacement, Fan: step 5, image 1 of 2 Neato XV-21 Fan Replacement, Fan: step 5, image 2 of 2
      • Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
      • Once the wires are disconnected lift the fan from the cavity
      Ask FixBot
    2. Neato XV-21 Fan Replacement: step 6, image 1 of 1
      • Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 52
All Time: 1,496
