Neato XV Signature Wheel Assembly Replacement
    1. Neato XV Signature Wheel Assembly Replacement, Wheel Assembly: step 1, image 1 of 1
      • Place the Neato with the bottom side facing up.
      Ask FixBot
    2. Neato XV Signature Wheel Assembly Replacement: step 2, image 1 of 1
      • Remove the four machine screws securing the main compartment plate using a Phillips #0 screwdriver.
      Ask FixBot
    3. Neato XV Signature Wheel Assembly Replacement: step 3, image 1 of 2 Neato XV Signature Wheel Assembly Replacement: step 3, image 2 of 2
      • Remove the main compartment plate, exposing the wheel axis and fan.
      Ask FixBot
    4. Neato XV Signature Wheel Assembly Replacement: step 4, image 1 of 1
      • Lift up on the wheel axis to remove the axle bar from its clasp.
      Ask FixBot
    5. Neato XV Signature Wheel Assembly Replacement: step 5, image 1 of 2 Neato XV Signature Wheel Assembly Replacement: step 5, image 2 of 2
      • Remove the axle bar from the wheel mount, exposing the suspension spring.
      Ask FixBot
    6. Neato XV Signature Wheel Assembly Replacement: step 6, image 1 of 2 Neato XV Signature Wheel Assembly Replacement: step 6, image 2 of 2
      • Unlatch the suspension spring from the wheel mount, exposing the wheel connector cable.
      Ask FixBot
    7. Neato XV Signature Wheel Assembly Replacement: step 7, image 1 of 1
      • Unplug the wheel connector cable.
      • Repeat steps 4-7 with the other wheel.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 434
