Neato XV Signature Motor Assembly Replacement
    1. Neato XV Signature Motor Assembly Replacement, Motor Assembly: step 1, image 1 of 2 Neato XV Signature Motor Assembly Replacement, Motor Assembly: step 1, image 2 of 2
      • Flip your Neato XV Signature robot over so that so are looking at the underside of it.
      Ask FixBot
    2. Neato XV Signature Motor Assembly Replacement: step 2, image 1 of 1
      • Using a Phillips head #2 screwdriver, unscrew the four 14 mm (1.4 cm) screws on the external panel that covers the motor assembly.
      • Be sure not to lose the screws.
      Ask FixBot
    3. Neato XV Signature Motor Assembly Replacement: step 3, image 1 of 2 Neato XV Signature Motor Assembly Replacement: step 3, image 2 of 2
      • Use plastic spudger to gently pry off the external panel to expose the motor assembly.
      Ask FixBot
    4. Neato XV Signature Motor Assembly Replacement: step 4, image 1 of 2 Neato XV Signature Motor Assembly Replacement: step 4, image 2 of 2
      • Gently lift the motor assembly straight up, out of place, being aware of the four mounting posts that hold the motor firmly in place.
      Ask FixBot
    5. Neato XV Signature Motor Assembly Replacement: step 5, image 1 of 3 Neato XV Signature Motor Assembly Replacement: step 5, image 2 of 3 Neato XV Signature Motor Assembly Replacement: step 5, image 3 of 3
      • Press the tab and gently lift straight up to disconnect the motor wires.
      Ask FixBot
    6. Neato XV Signature Motor Assembly Replacement: step 6, image 1 of 3 Neato XV Signature Motor Assembly Replacement: step 6, image 2 of 3 Neato XV Signature Motor Assembly Replacement: step 6, image 3 of 3
      • After disconnecting the wire clip, remove the motor assembly out of the compartment.
      • With the replacement motor, you can now begin reassembly.
      Ask FixBot
To finish connecting the new motor assembly, follow these steps in reverse order. Be sure to replace the back external panel and four screws to tightly secure.
Emily Cardella
107 Reputation
1 Guide authored
USF Tampa, Team 15-5, Remmell Spring 2017 Member of USF Tampa, Team 15-5, Remmell Spring 2017
USFT-REMMELL-S17S15G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 34
All Time: 1,774
