Neato Botvac D8000 Wheel Replacement
    1. Neato Botvac D8000 Wheel Replacement, Brushes: step 1, image 1 of 1
      • Place the vacuum on its back so the brushes are visible.
      Ask FixBot
    2. Neato Botvac D8000 Wheel Replacement: step 2, image 1 of 3 Neato Botvac D8000 Wheel Replacement: step 2, image 2 of 3 Neato Botvac D8000 Wheel Replacement: step 2, image 3 of 3
      • Remove the four 10 mm screws with a Torx T10 screwdriver.
      Ask FixBot
    3. Neato Botvac D8000 Wheel Replacement: step 3, image 1 of 2 Neato Botvac D8000 Wheel Replacement: step 3, image 2 of 2
      • Remove the rotary brush simply by grabbing it firmly and pulling it off.
      • Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
      Ask FixBot
    4. Neato Botvac D8000 Wheel Replacement: step 4, image 1 of 2 Neato Botvac D8000 Wheel Replacement: step 4, image 2 of 2
      • Remove the brush by simply pulling it out.
      • From there you can clean it or replace the brush with a new one.
      Ask FixBot
    1. Neato Botvac D8000 Wheel Replacement, Top Face Panel: step 5, image 1 of 1
      • Grab the rear bumper with both hands on either side.
      Ask FixBot
    2. Neato Botvac D8000 Wheel Replacement: step 6, image 1 of 2 Neato Botvac D8000 Wheel Replacement: step 6, image 2 of 2
      • Firmly pull the bumper forward at a steady pace.
      • When pulling the bumper forward avoid being too rough because the bumper might break.
      Ask FixBot
    3. Neato Botvac D8000 Wheel Replacement: step 7, image 1 of 2 Neato Botvac D8000 Wheel Replacement: step 7, image 2 of 2
      • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
      Ask FixBot
    4. Neato Botvac D8000 Wheel Replacement: step 8, image 1 of 3 Neato Botvac D8000 Wheel Replacement: step 8, image 2 of 3 Neato Botvac D8000 Wheel Replacement: step 8, image 3 of 3
      • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
      Ask FixBot
    5. Neato Botvac D8000 Wheel Replacement: step 9, image 1 of 3 Neato Botvac D8000 Wheel Replacement: step 9, image 2 of 3 Neato Botvac D8000 Wheel Replacement: step 9, image 3 of 3
      • Push the clips, located in the back side, inward.
      • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
      • When you lift the top cover be careful because the wires are thin and fragile.
      Ask FixBot
    6. Neato Botvac D8000 Wheel Replacement: step 10, image 1 of 1
      • Once you have carefully removed the wire clip; you can fully remove the top cover.
      Ask FixBot
    1. Neato Botvac D8000 Wheel Replacement, Wheel: step 11, image 1 of 3 Neato Botvac D8000 Wheel Replacement, Wheel: step 11, image 2 of 3 Neato Botvac D8000 Wheel Replacement, Wheel: step 11, image 3 of 3
      • Locate the screws that mount the wheel extension to the Robot.
      • Unscrew the four 11mm screws indicated with a Torx T10 screwdriver to remove the frame.
      • Make sure to remove the metallic weight. However, this does not require the removal of any screws.
      Ask FixBot
    2. Neato Botvac D8000 Wheel Replacement: step 12, image 1 of 3 Neato Botvac D8000 Wheel Replacement: step 12, image 2 of 3 Neato Botvac D8000 Wheel Replacement: step 12, image 3 of 3
      • Delicately lift up the frame holding the laser. This will access the wheels.
      • Detach the wheel wires that are connected to the motherboard.
      • Once the wires are detached, the wheel are free from their casing.
      Ask FixBot
    3. Neato Botvac D8000 Wheel Replacement: step 13, image 1 of 2 Neato Botvac D8000 Wheel Replacement: step 13, image 2 of 2
      • Use a Torx T15 screwdriver to remove the 32.5mm screw.
      • Finally, just hold and separate the wheel from its axle.
      Ask FixBot
Ruth Lopez
280 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 4,178
