Neato Botvac D8000 Battery Replacement
    1. Neato Botvac D8000 Battery Replacement, Battery: step 1, image 1 of 2 Neato Botvac D8000 Battery Replacement, Battery: step 1, image 2 of 2
      • Turn the robot upside down to locate the battery cover.
      Ask FixBot
    2. Neato Botvac D8000 Battery Replacement: step 2, image 1 of 3 Neato Botvac D8000 Battery Replacement: step 2, image 2 of 3 Neato Botvac D8000 Battery Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew both of the 20mm screws.
      • Gently lift the battery cover.
      • Remove the battery cover to reveal the battery.
      Ask FixBot
    3. Neato Botvac D8000 Battery Replacement: step 3, image 1 of 3 Neato Botvac D8000 Battery Replacement: step 3, image 2 of 3 Neato Botvac D8000 Battery Replacement: step 3, image 3 of 3
      • Use a flathead screwdriver to push down on the latch of the battery clip.
      • Simultaneously, pull on the battery while pushing down on the latch to detach the battery from the clip.
      • Do not pull on the wires that are connected to the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 38
All Time: 1,159
