Neato Botvac D75 Motherboard Replacement
    1. Neato Botvac D75 Motherboard Replacement, Battery: step 1, image 1 of 3 Neato Botvac D75 Motherboard Replacement, Battery: step 1, image 2 of 3 Neato Botvac D75 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
      • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
      Ask FixBot
    2. Neato Botvac D75 Motherboard Replacement: step 2, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 2, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 2, image 3 of 3
      • Lift battery cover out.
      Ask FixBot
    3. Neato Botvac D75 Motherboard Replacement: step 3, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 3, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 3, image 3 of 3
      • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
      • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
      Ask FixBot
    1. Neato Botvac D75 Motherboard Replacement, Brushes: step 4, image 1 of 3 Neato Botvac D75 Motherboard Replacement, Brushes: step 4, image 2 of 3 Neato Botvac D75 Motherboard Replacement, Brushes: step 4, image 3 of 3
      • To remove the rotary brush simply grasp it firmly and pull it off.
      Ask FixBot
    2. Neato Botvac D75 Motherboard Replacement: step 5, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 5, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 5, image 3 of 3
      • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
      • With a little force it should come out.
      • The boxes show you were the clips are that hold this piece
      Ask FixBot
    3. Neato Botvac D75 Motherboard Replacement: step 6, image 1 of 1
      • Once the black piece has been taken out, the brush just comes out easily.
      Ask FixBot
    1. Neato Botvac D75 Motherboard Replacement, LCD Screen: step 7, image 1 of 2 Neato Botvac D75 Motherboard Replacement, LCD Screen: step 7, image 2 of 2
      • Firmly grasp the back cover and pull away from the Botvac one side at a time.
      • Removing the cover will expose two 1.3mm T10 screws that must be removed to separate the cover halves.
      Ask FixBot
    2. Neato Botvac D75 Motherboard Replacement: step 8, image 1 of 2 Neato Botvac D75 Motherboard Replacement: step 8, image 2 of 2
      • Remove these two 13mm T10 screws. You will need to use the extension in your tool set since they are deep in the casting.
      Ask FixBot
    3. Neato Botvac D75 Motherboard Replacement: step 9, image 1 of 2 Neato Botvac D75 Motherboard Replacement: step 9, image 2 of 2
      • Eight 13mm T10 screws on the underside of the Botvac hold the casing together. These screws are not self-retained so make sure that you don’t lose them in the disassembly process.
      Ask FixBot
    4. Neato Botvac D75 Motherboard Replacement: step 10, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 10, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 10, image 3 of 3
      • The screws pictured here on either side of the Botvac require the extension in your tool set to be removed.
      Ask FixBot
    5. Neato Botvac D75 Motherboard Replacement: step 11, image 1 of 2 Neato Botvac D75 Motherboard Replacement: step 11, image 2 of 2
      • On the back of the Botvac there are two retaining tabs that must be pressed to be released.
      • With the tabs released the top and bottom cover halves can be separated.
      Ask FixBot
    6. Neato Botvac D75 Motherboard Replacement: step 12, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 12, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 12, image 3 of 3
      • Carefully lift the top cover of the Botvac. On the right side of the Botvac is where you'll find the LCD screen connector to the motherboard. Carefully pull on the connector to disconnect it from the motherboard.
      Ask FixBot
    7. Neato Botvac D75 Motherboard Replacement: step 13, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 13, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 13, image 3 of 3
      • There are two 0.5cm #1 Phillips screws holding the LCD screen to the top cover. Remove these screws to lift screen off the cover.
      Ask FixBot
    8. Neato Botvac D75 Motherboard Replacement: step 14, image 1 of 3 Neato Botvac D75 Motherboard Replacement: step 14, image 2 of 3 Neato Botvac D75 Motherboard Replacement: step 14, image 3 of 3
      • With the two screws removed you may lift the screen off the cover. Carefully remove the connector from the screen by pulling on the connector.
      Ask FixBot
    1. Neato Botvac D75 Motherboard Replacement, Motherboard: step 15, image 1 of 3 Neato Botvac D75 Motherboard Replacement, Motherboard: step 15, image 2 of 3 Neato Botvac D75 Motherboard Replacement, Motherboard: step 15, image 3 of 3
      • Carefully remove the plugs connected to top side of the motherboard.
      • Be careful to not pull the white casings that attach the plugs to the board.
      Ask FixBot
    2. Neato Botvac D75 Motherboard Replacement: step 16, image 1 of 1
      • Remove the cables attached to the under side of the motherboard.
      • Similarly to the previous step, be careful as to not remove the casing attaching the cable to the board.
      Ask FixBot
3 other people completed this guide.
Juan Cornejo
606 Reputation
5 Guides authored
USF Tampa, Team S6-G5, Lacy Spring 2017 Member of USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Members
60 Guides authored
1 Guide Comment
Can you replace the silver cylindrical battery looking part on the motherboard? If yes, where can I buy a replacement?
Raymundo Valadez - Reply Share
Past 24 Hours: 10
Past 7 Days: 29
Past 30 Days: 82
All Time: 5,791
