Neato Botvac D75 Battery Replacement
    1. Neato Botvac D75 Battery Replacement, Battery: step 1, image 1 of 3 Neato Botvac D75 Battery Replacement, Battery: step 1, image 2 of 3 Neato Botvac D75 Battery Replacement, Battery: step 1, image 3 of 3
      • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
      • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
      Ask FixBot
    2. Neato Botvac D75 Battery Replacement: step 2, image 1 of 3 Neato Botvac D75 Battery Replacement: step 2, image 2 of 3 Neato Botvac D75 Battery Replacement: step 2, image 3 of 3
      • Lift battery cover out.
      Ask FixBot
    3. Neato Botvac D75 Battery Replacement: step 3, image 1 of 3 Neato Botvac D75 Battery Replacement: step 3, image 2 of 3 Neato Botvac D75 Battery Replacement: step 3, image 3 of 3
      • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
      • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
      Ask FixBot
Juan Cornejo
606 Reputation
5 Guides authored
USF Tampa, Team S6-G5, Lacy Spring 2017 Member of USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Members
60 Guides authored
1 Guide Comment
Thanks for the tuto.
an additionnal info when having a battery issue, is to the reset to new battery. enter the menu, then help, and chose new battery.
it seems the neato system is set for planned obsolescence… unfortunatly for customers….
so I did it because battery stayed empty while plugged and switch found ok . And new my botvac is ok, like new!!
Nom - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 3,024
