Neato Botvac Connected Screen Replacement
    1. Neato Botvac Connected Screen Replacement, Screen: step 1, image 1 of 3 Neato Botvac Connected Screen Replacement, Screen: step 1, image 2 of 3 Neato Botvac Connected Screen Replacement, Screen: step 1, image 3 of 3
      • Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
      • Remove the four screws lining the front roller using a TR10 Torx screwdriver.
      • Remove the black panel behind and in front of the roller.
      • Gently lift the roller by the right side to remove it.
      Ask FixBot
    2. Neato Botvac Connected Screen Replacement: step 2, image 1 of 1
      • Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
      • Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
      Ask FixBot
    3. Neato Botvac Connected Screen Replacement: step 3, image 1 of 3 Neato Botvac Connected Screen Replacement: step 3, image 2 of 3 Neato Botvac Connected Screen Replacement: step 3, image 3 of 3
      • Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
      Ask FixBot
    4. Neato Botvac Connected Screen Replacement: step 4, image 1 of 2 Neato Botvac Connected Screen Replacement: step 4, image 2 of 2
      • Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
      • Remove the additional two TR10 screws from the top of the Botvac.
      • Remove the dustbin.
      Ask FixBot
    5. Neato Botvac Connected Screen Replacement: step 5, image 1 of 3 Neato Botvac Connected Screen Replacement: step 5, image 2 of 3 Neato Botvac Connected Screen Replacement: step 5, image 3 of 3
      • Pry the clips on the front of the robot apart.
      • Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
      • Make certain not to not to tear any wires out of the port.
      • Lay the top of the robot inside up.
      Ask FixBot
    6. Neato Botvac Connected Screen Replacement: step 6, image 1 of 2 Neato Botvac Connected Screen Replacement: step 6, image 2 of 2
      • Unplug the beige connector with a spudger. Be careful not to tear out any wires.
      • Remove the two screws from the screen using a TR10 Torx screwdriver.
      • Remove the screen from the vacuum.
      Ask FixBot
Jerome
365 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 548
