Neato BOTVAC CONNECTED Side Wheel Replacement
    1. Neato BOTVAC CONNECTED Side Wheel Replacement, Battery: step 1, image 1 of 1
      • Place the top of the Neato Botvac Connected against a flat surface.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Side Wheel Replacement: step 2, image 1 of 2 Neato BOTVAC CONNECTED Side Wheel Replacement: step 2, image 2 of 2
      • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Side Wheel Replacement: step 3, image 1 of 2 Neato BOTVAC CONNECTED Side Wheel Replacement: step 3, image 2 of 2
      • Using the spudger, remove the panel covering the battery.
      Ask FixBot
    4. Neato BOTVAC CONNECTED Side Wheel Replacement: step 4, image 1 of 3 Neato BOTVAC CONNECTED Side Wheel Replacement: step 4, image 2 of 3 Neato BOTVAC CONNECTED Side Wheel Replacement: step 4, image 3 of 3
      • Gently remove the connecting wires attached to the battery.
      • The wires are attached to the vacuum through a clip.
      Ask FixBot
    5. Neato BOTVAC CONNECTED Side Wheel Replacement: step 5, image 1 of 1
      • Using the spudger, gently remove the battery from the device.
      Ask FixBot
    1. Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: step 6, image 1 of 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: step 6, image 2 of 2
      • Remove the following screws with a Torx screwdriver:
      • Four 2.3 mm screws.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Side Wheel Replacement: step 7, image 1 of 1
      • Gently remove the thin panel held by the four screws with a spudger.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Side Wheel Replacement: step 8, image 1 of 1
      • Gently remove the two small wheels, and the axles attached to them.
      Ask FixBot
    4. Neato BOTVAC CONNECTED Side Wheel Replacement: step 9, image 1 of 1
      • Gently remove the panel that is on top of the front roller with the spudger.
      Ask FixBot
    5. Neato BOTVAC CONNECTED Side Wheel Replacement: step 10, image 1 of 1
      • Gently remove the front brush.
      Ask FixBot
    1. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: step 11, image 1 of 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: step 11, image 2 of 2
      • Gently twist the side brush back and forth.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Side Wheel Replacement: step 12, image 1 of 3 Neato BOTVAC CONNECTED Side Wheel Replacement: step 12, image 2 of 3 Neato BOTVAC CONNECTED Side Wheel Replacement: step 12, image 3 of 3
      • Spin the side brush counter counterclockwise.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Side Wheel Replacement: step 13, image 1 of 1
      • Use the spudger to gently pry up and remove the side brush.
      Ask FixBot
    1. Neato BOTVAC CONNECTED Side Wheel Replacement, Filter: step 14, image 1 of 1
      • Flip the cleaner around and locate the front panel.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Side Wheel Replacement: step 15, image 1 of 1
      • Gently remove the front panel by opening it with a spudger.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Side Wheel Replacement: step 16, image 1 of 2 Neato BOTVAC CONNECTED Side Wheel Replacement: step 16, image 2 of 2
      • Use the spudger to gently remove the paper filter.
      Ask FixBot
    1. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Wheel: step 17, image 1 of 1
      • Remove the following screws with a TR10 Torx screwdriver:
      • Six 2.3 mm screws.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Side Wheel Replacement: step 18, image 1 of 2 Neato BOTVAC CONNECTED Side Wheel Replacement: step 18, image 2 of 2
      • Remove the front bumper by pulling it horizontally on each side.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Side Wheel Replacement: step 19, image 1 of 1
      • Remove the screw that is directly attached to the wheel on the side using a Phillips #2 screwdriver.
      Ask FixBot
    4. Neato BOTVAC CONNECTED Side Wheel Replacement: step 20, image 1 of 1
      • Remove the two 2.3 mm screws on the front of the vacuum with a TR10 Torx screwdriver.
      Ask FixBot
    5. Neato BOTVAC CONNECTED Side Wheel Replacement: step 21, image 1 of 1
      • Remove the layer below the front bumper by pressing firmly on the two levers located nearby.
      Ask FixBot
    6. Neato BOTVAC CONNECTED Side Wheel Replacement: step 22, image 1 of 3 Neato BOTVAC CONNECTED Side Wheel Replacement: step 22, image 2 of 3 Neato BOTVAC CONNECTED Side Wheel Replacement: step 22, image 3 of 3
      • Gently take out the top panel, and take out the connecting wires.
      Ask FixBot
    7. Neato BOTVAC CONNECTED Side Wheel Replacement: step 23, image 1 of 1
      • Two 2.3 mm screws.
      Ask FixBot
    8. Neato BOTVAC CONNECTED Side Wheel Replacement: step 24, image 1 of 1
      • Flip around the vacuum and remove the wheel with the spudger.
      Ask FixBot
Justin Silva
645 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 45
All Time: 803
