Neato BOTVAC CONNECTED Filter Replacement
    1. Neato BOTVAC CONNECTED Filter Replacement, Battery: step 1, image 1 of 1
      • Place the top of the Neato Botvac Connected against a flat surface.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Filter Replacement: step 2, image 1 of 2 Neato BOTVAC CONNECTED Filter Replacement: step 2, image 2 of 2
      • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Filter Replacement: step 3, image 1 of 2 Neato BOTVAC CONNECTED Filter Replacement: step 3, image 2 of 2
      • Using the spudger, remove the panel covering the battery.
      Ask FixBot
    4. Neato BOTVAC CONNECTED Filter Replacement: step 4, image 1 of 3 Neato BOTVAC CONNECTED Filter Replacement: step 4, image 2 of 3 Neato BOTVAC CONNECTED Filter Replacement: step 4, image 3 of 3
      • Gently remove the connecting wires attached to the battery.
      • The wires are attached to the vacuum through a clip.
      Ask FixBot
    5. Neato BOTVAC CONNECTED Filter Replacement: step 5, image 1 of 1
      • Using the spudger, gently remove the battery from the device.
      Ask FixBot
    1. Neato BOTVAC CONNECTED Filter Replacement, Filter: step 6, image 1 of 1
      • Flip the cleaner around and locate the front panel.
      Ask FixBot
    2. Neato BOTVAC CONNECTED Filter Replacement: step 7, image 1 of 1
      • Gently remove the front panel by opening it with a spudger.
      Ask FixBot
    3. Neato BOTVAC CONNECTED Filter Replacement: step 8, image 1 of 2 Neato BOTVAC CONNECTED Filter Replacement: step 8, image 2 of 2
      • Use the spudger to gently remove the paper filter.
      Ask FixBot
Justin Silva
645 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 304
