Nanit Pro N301 Camera Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
152
All Time:
3,272
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Nanit Pro N301 is not producing a clear image or any image at all, use this guide to replace the camera lens. Some of the pieces are very small so make sure you have a tool that can grab tiny materials if you are unable to do so with your fingers. Make your device is not plugged in and connected to a power source during the repair.
Tools
    1. Nanit Pro N301 Camera Replacement, Camera: step 1, image 1 of 3 Nanit Pro N301 Camera Replacement, Camera: step 1, image 2 of 3 Nanit Pro N301 Camera Replacement, Camera: step 1, image 3 of 3
      • Insert an opening pick into the seam between the front and rear case.
      • Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
      • Separate the front and rear case.
      Ask FixBot
    2. Nanit Pro N301 Camera Replacement: step 2, image 1 of 1
      • Remove the four 4 mm T6 Torx screws from each corner of the circuit board.
      • Lift the circuit board out of the chassis.
      Ask FixBot
    3. Nanit Pro N301 Camera Replacement: step 3, image 1 of 3 Nanit Pro N301 Camera Replacement: step 3, image 2 of 3 Nanit Pro N301 Camera Replacement: step 3, image 3 of 3
      • Remove the rubber gasket around the camera.
      Ask FixBot
    4. Nanit Pro N301 Camera Replacement: step 4, image 1 of 1
      • Disconnect the white camera connector from the circuit board.
      • Do not pull on the wires.
      Ask FixBot
    5. Nanit Pro N301 Camera Replacement: step 5, image 1 of 1
      • Remove the small Phillips screw that secures the camera.
      Ask FixBot
    6. Nanit Pro N301 Camera Replacement: step 6, image 1 of 2 Nanit Pro N301 Camera Replacement: step 6, image 2 of 2
      • Remove the filter from behind the camera lens.
      Ask FixBot
    7. Nanit Pro N301 Camera Replacement: step 7, image 1 of 2 Nanit Pro N301 Camera Replacement: step 7, image 2 of 2
      • Use a T4 Torx screwdriver to remove the screws that secure the computer chip to the white plastic bracket.
      Ask FixBot
    8. Nanit Pro N301 Camera Replacement: step 8, image 1 of 1
      • Gently pull the circuit board away from the white plastic bracket.
      Ask FixBot
    9. Nanit Pro N301 Camera Replacement: step 9, image 1 of 2 Nanit Pro N301 Camera Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two screws that secure the underside of the camera.
      Ask FixBot
    10. Nanit Pro N301 Camera Replacement: step 10, image 1 of 1
      • Gently lift the camera up and off the circuit board.
      Ask FixBot
2 other people completed this guide.
Ryan Maher
211 Reputation
1 Guide authored
IUPUI, Team 3-1, Harley Spring 2024 Member of IUPUI, Team 3-1, Harley Spring 2024
IUPUI-HARLEY-S24S3G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 152
All Time: 3,272
