Up to 20% off select tools
Nail Clipper Reassembly
Views: 166K
View statistics:
Past 24 Hours:
59
Past 7 Days:
461
Past 30 Days:
2,034
All Time:
165,756
Comments: 44
11 comments on steps, 33 guide comments.
Go to guide comments
Completed: 102
102 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Have you ever brought nail clippers on a trip, only to find that they had fallen apart in your bag. Before buying a new pair, try fixing them with this simple guide. As long as you have all three necessary parts, if you follow these easy steps your nail clippers will be as good as new.
    1. Nail Clipper Reassembly, Nail Clipper Reassembly: step 1, image 1 of 3 Nail Clipper Reassembly, Nail Clipper Reassembly: step 1, image 2 of 3 Nail Clipper Reassembly, Nail Clipper Reassembly: step 1, image 3 of 3
      • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
      • The side of the rod with the notch should be inserted first.
      • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
      Ask FixBot
    2. Nail Clipper Reassembly: step 2, image 1 of 1
      • Compress the body of the clippers to reveal the notch.
      Ask FixBot
    3. Nail Clipper Reassembly: step 3, image 1 of 1
      • Rotate the rod until the notch opening faces away from the body.
      • This allows for easier completion of the following step.
      Ask FixBot
    4. Nail Clipper Reassembly: step 4, image 1 of 3 Nail Clipper Reassembly: step 4, image 2 of 3 Nail Clipper Reassembly: step 4, image 3 of 3
      • Place the hole of the lever into the revealed rod notch.
      • Release the compressed nail clipper body to lock the lever into place.
      • Note: Position of the lever does not matter at this point.
      Ask FixBot
    5. Nail Clipper Reassembly: step 5, image 1 of 3 Nail Clipper Reassembly: step 5, image 2 of 3 Nail Clipper Reassembly: step 5, image 3 of 3
      • Swivel the lever into its normal position, and test the nail clippers' functionality.
      Ask FixBot
If you follow these steps, your nail clippers should be back to working order.
102 other people completed this guide.
Author
with
Robert Weber
2,158 Reputation
1 Guide authored
Cal Poly, Team 30-5, Green Spring 2015 Member of Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Members
72 Guides authored
33 Guide Comments
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - Reply Share
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - Reply Share
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - Reply Share
That's why it says reassembly 🤨
Blake Jordan-Borns - Reply Share
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - Reply Share
Past 24 Hours: 59
Past 7 Days: 461
Past 30 Days: 2,034
All Time: 165,756
