Nabi Jr Motherboard Replacement
    1. Nabi Jr Motherboard Replacement, Rear Case: step 1, image 1 of 1
      • Remove the red rubber case from the device. This should come off with ease.
      Ask FixBot
    2. Nabi Jr Motherboard Replacement: step 2, image 1 of 1
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      Ask FixBot
    3. Nabi Jr Motherboard Replacement: step 3, image 1 of 1
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      Ask FixBot
    4. Nabi Jr Motherboard Replacement: step 4, image 1 of 1
      • After loosening the back cover, remove it from the device so you can get at the innards.
      Ask FixBot
    1. Nabi Jr Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
      Ask FixBot
    2. Nabi Jr Motherboard Replacement: step 6, image 1 of 1
      • De-solder the grey wire from motherboard
      Ask FixBot
    3. Nabi Jr Motherboard Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to peel off all yellow tape from the motherboard
      • Yellow tape is used in all locations where there is ribbon cable present.
      Ask FixBot
    4. Nabi Jr Motherboard Replacement: step 8, image 1 of 2 Nabi Jr Motherboard Replacement: step 8, image 2 of 2
      • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
      • Pull black locking tabs up in opposite direction of ribbon cable to remove.
      • Use tweezers to pull the ribbon cable out of the locking tab's slot
      Ask FixBot
    5. Nabi Jr Motherboard Replacement: step 9, image 1 of 2 Nabi Jr Motherboard Replacement: step 9, image 2 of 2
      • Lift motherboard to separate it the from the case shell.
      Ask FixBot
Kaila Joy
86 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 19
All Time: 1,456
