Up to 20% off select tools
Nabi Jr Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
77
All Time:
834
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nabi Jr Camera Replacement, Rear Case: step 1, image 1 of 1
      • Remove the red rubber case from the device. This should come off with ease.
      Ask FixBot
    2. Nabi Jr Camera Replacement: step 2, image 1 of 1
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      Ask FixBot
    3. Nabi Jr Camera Replacement: step 3, image 1 of 1
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      Ask FixBot
    4. Nabi Jr Camera Replacement: step 4, image 1 of 1
      • After loosening the back cover, remove it from the device so you can get at the innards.
      Ask FixBot
    1. Nabi Jr Camera Replacement, Camera: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers remove tape that connects the board to the camera's ribbon cable.
      • The ribbon cable is inserted into a slot on the board.
      • Lift the slot's locking tab up to easily remove the ribbon cable from the board.
      • May require force
      Ask FixBot
    2. Nabi Jr Camera Replacement: step 6, image 1 of 1
      • Place the new camera piece in place of the old and plug its ribbon cable back into the respective slot on the board.
      • Make sure the locking tab on the slot is in its up position before inserting tape.
      • Once the tape is inserted press the locking tab back to its down position to securely fasten the ribbon cable.
      Ask FixBot
Author
with
Kaila Joy
86 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 77
All Time: 834
