Up to 20% off select tools
Nabi Jr Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
100
All Time:
12,697
Comments: 7
7 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nabi Jr Battery Replacement, Rear Case: step 1, image 1 of 1
      • Remove the red rubber case from the device. This should come off with ease.
      Ask FixBot
    2. Nabi Jr Battery Replacement: step 2, image 1 of 1
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      Ask FixBot
    3. Nabi Jr Battery Replacement: step 3, image 1 of 1
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      Ask FixBot
    4. Nabi Jr Battery Replacement: step 4, image 1 of 1
      • After loosening the back cover, remove it from the device so you can get at the innards.
      Ask FixBot
    1. Nabi Jr Battery Replacement, Battery: step 5, image 1 of 1
      • Lift the battery up from the motherboard.
      • Don't rip the soldered wires from the board.
      • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
      Ask FixBot
    2. Nabi Jr Battery Replacement: step 6, image 1 of 1
      • Remove the battery from the motherboard
      • De-solder the colored wires
      • Be sure to note the order in which the wires are connected to the board before desoldering them.
      • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
      Ask FixBot
    3. Nabi Jr Battery Replacement: step 7, image 1 of 2 Nabi Jr Battery Replacement: step 7, image 2 of 2
      • Replace the old battery with the new one
      • Solder the wires of the new battery into the pads on the motherboard
      • Be careful when soldering the wires in. Soldering iron will be extremely hot
      Ask FixBot
    4. Nabi Jr Battery Replacement: step 8, image 1 of 1
      • Once the wires are fully soldered, put the new battery back to the initial position
      • Close the case by putting the back cover back on the device
      • Will take some force
      • Make sure the battery is not in the way of the back cover
      Ask FixBot
    5. Nabi Jr Battery Replacement: step 9, image 1 of 1
      • Once the back cover is on, screw in the four screws that you had taken off in the beginning
      • Put the red rubber casing back on.
      Ask FixBot
If all the steps were followed correctly, the device should be fully closed and ready to go
4 other people completed this guide.
Author
with
Jimmy Nguyen
271 Reputation
2 Guides authored
7 Guide Comments
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - Reply Share
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow - Reply Share
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - Reply Share
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke - Reply Share
Where can I buy the battery live in Mexico
Roos - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 100
All Time: 12,697
