Nabi 2S Speakers Replacement
    1. Nabi 2S Speakers Replacement, Nabi 2S Disassembly: step 1, image 1 of 1
      • Remove the red rubber case from the device.
      Ask FixBot
    2. Nabi 2S Speakers Replacement: step 2, image 1 of 2 Nabi 2S Speakers Replacement: step 2, image 2 of 2
      • Make sure the screen is facing away from you and the back cover is facing you.
      • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
      Ask FixBot
    3. Nabi 2S Speakers Replacement: step 3, image 1 of 1
      • Using the plastic opening tool, remove the case.
      • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
      • It is helpful to pry at the corners first to loosen the case.
      Ask FixBot
    4. Nabi 2S Speakers Replacement: step 4, image 1 of 1
      • After the back case is loosened, remove it from the device to change or access the battery.
      Ask FixBot
    1. Nabi 2S Speakers Replacement, Speakers: step 5, image 1 of 2 Nabi 2S Speakers Replacement, Speakers: step 5, image 2 of 2
      • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a clockwise rotation.
      Ask FixBot
    2. Nabi 2S Speakers Replacement: step 6, image 1 of 2 Nabi 2S Speakers Replacement: step 6, image 2 of 2
      • The speakers are attached to the device via wires that are connected to a circuit. Grasp the circuit connected to the right speaker.
      • Slide the connected wires from the circuit to detach the speakers.
      Ask FixBot
    3. Nabi 2S Speakers Replacement: step 7, image 1 of 3 Nabi 2S Speakers Replacement: step 7, image 2 of 3 Nabi 2S Speakers Replacement: step 7, image 3 of 3
      • Lift the circuit board to get better access for removing the speaker.
      • Grasp the speaker with your fingers and lift it from the plastic
      Ask FixBot
    4. Nabi 2S Speakers Replacement: step 8, image 1 of 2 Nabi 2S Speakers Replacement: step 8, image 2 of 2
      • Repeat steps 6 and 7 for the second speaker on the left side.
      • The circuit board should still be loose to remove the speaker.
      Ask FixBot
3 other people completed this guide.
Riana Ramirez
680 Reputation
4 Guides authored
Marist, Team 1-4, Laflen Spring 2016 Member of Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Members
55 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 60
All Time: 613
