Up to 20% off select tools
Nabi 2S Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
19
Past 30 Days:
95
All Time:
1,457
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will aid you in the process of removing the battery of the device. This is useful in replacing a broken or dis-functioning battery.
    1. Nabi 2S Battery Replacement, Nabi 2S Disassembly: step 1, image 1 of 1
      • Remove the red rubber case from the device.
      Ask FixBot
    2. Nabi 2S Battery Replacement: step 2, image 1 of 2 Nabi 2S Battery Replacement: step 2, image 2 of 2
      • Make sure the screen is facing away from you and the back cover is facing you.
      • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
      Ask FixBot
    3. Nabi 2S Battery Replacement: step 3, image 1 of 1
      • Using the plastic opening tool, remove the case.
      • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
      • It is helpful to pry at the corners first to loosen the case.
      Ask FixBot
    4. Nabi 2S Battery Replacement: step 4, image 1 of 1
      • After the back case is loosened, remove it from the device to change or access the battery.
      Ask FixBot
    1. Nabi 2S Battery Replacement, Battery: step 5, image 1 of 3 Nabi 2S Battery Replacement, Battery: step 5, image 2 of 3 Nabi 2S Battery Replacement, Battery: step 5, image 3 of 3
      • Grasp the circuit connected to the battery via wires.
      • Slide the wires from the circuit to detach it.
      Ask FixBot
    2. Nabi 2S Battery Replacement: step 6, image 1 of 2 Nabi 2S Battery Replacement: step 6, image 2 of 2
      • After the circuit is detached, the battery will be easily removable.
      • Don’t rip the battery off of the board.
      • The battery is stuck with adhesive tape to the board.
      • Use a plastic opening tool to apply pressure to the battery and lift it up from the adhesive.
      Ask FixBot
4 other people completed this guide.
Author
with
Riana Ramirez
680 Reputation
4 Guides authored
Marist, Team 1-4, Laflen Spring 2016 Member of Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 95
All Time: 1,457
