Up to 20% off select tools
Nabi 2 Battery Replacement
Views: 11K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
111
All Time:
10,770
Comments: 3
3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 35 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to remove and replace your Nabi 2's battery. The battery powers your device, and over time your battery may lose its ability to function correctly. There are many reasons to perform this repair, but the most common causes are the device not turning on, and the device not holding a charge. This repair involves the use of a soldering iron; be very careful not to touch the hot end of the iron while it is plugged in. It is recommended to document the order of the battery wires before you detach them so that you can attach the new battery's wires in the correct order.
    1. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: step 1, image 1 of 3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: step 1, image 2 of 3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: step 1, image 3 of 3
      • Remove the rubber bumper from the tablet.
      Ask FixBot
    2. Nabi 2 Battery Replacement: step 2, image 1 of 2 Nabi 2 Battery Replacement: step 2, image 2 of 2
      • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
      Ask FixBot
    3. Nabi 2 Battery Replacement: step 3, image 1 of 3 Nabi 2 Battery Replacement: step 3, image 2 of 3 Nabi 2 Battery Replacement: step 3, image 3 of 3
      • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
      • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
      • Do not force the clips open, as they are fairly easy to break
      Ask FixBot
    1. Nabi 2 Battery Replacement, Battery: step 4, image 1 of 3 Nabi 2 Battery Replacement, Battery: step 4, image 2 of 3 Nabi 2 Battery Replacement, Battery: step 4, image 3 of 3
      • Use the spudger to pop the battery out of place and set it aside.
      Ask FixBot
    2. Nabi 2 Battery Replacement: step 5, image 1 of 3 Nabi 2 Battery Replacement: step 5, image 2 of 3 Nabi 2 Battery Replacement: step 5, image 3 of 3
      • Desolder the battery connection and remove the battery completely
      • Note the color order for future replacemement
      Ask FixBot
5 other people completed this guide.
Author
with
Michelle
899 Reputation
4 Guides authored
USF Tampa, Team 4-3, Lacy Spring 2016 Member of USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Members
84 Guides authored
3 Guide Comments
Was hoping you could provide the replacement part number for this battery.
ellenanders5 - Reply Share
It shows on the picture: 1ICP6/68/112
Zoltan - Reply Share
Hi,
where i can buy this replacement battery?
Thanks
Antanas Stankus - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 111
All Time: 10,770
