NPET K10V3 USB Cable Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
54
All Time:
517
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide gives detailed instructions on how to replace the NPET K10V3 USB cable. If you are having trouble with your keyboard being unresponsive or losing connection, follow this detailed guide on how to remove the current cable.
Hazards:
  • Electric shock
  • Sharp objects
Special Requirements:
  • Disconnect keyboard from power source
  • Clean workspace
  • Careful removal to prevent risk of damaging delicate parts
Tools
    1. NPET K10V3 USB Cable Replacement, Kickstand: step 1, image 1 of 1
      • Flip the keyboard over so the bottom is facing upwards.
      • Remove five 4.5 mm screws using a Phillips #2 screwdriver.
      • Remove three 9 mm screws using a Phillips #2 screwdriver.
      Ask FixBot
    2. NPET K10V3 USB Cable Replacement: step 2, image 1 of 1
      • Remove the kickstand from the keyboard.
      Ask FixBot
    1. NPET K10V3 USB Cable Replacement, USB Cable: step 3, image 1 of 3 NPET K10V3 USB Cable Replacement, USB Cable: step 3, image 2 of 3 NPET K10V3 USB Cable Replacement, USB Cable: step 3, image 3 of 3
      • Remove the COM2 connection from its housing with a set of tweezers.
      • Do not pull by the wires; only pull by the plastic housing.
      • Remove the USB cable from the device.
      Ask FixBot
Matthew Costa
343 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 54
All Time: 517
