NPET K10V3 Membrane Replacement
  1. NPET K10V3 Membrane Replacement, Key Cap: step 1, image 1 of 1
    • Remove the keyboard from its power source.
    Ask FixBot
  2. NPET K10V3 Membrane Replacement: step 2, image 1 of 2 NPET K10V3 Membrane Replacement: step 2, image 2 of 2
    • Firmly grasp the key that will be removed.
    • Remove the keycap by pulling directly upward.
    • Not pulling straight upward or securely will cause damage to the device.
    • If your fingers cannot get a good grip the key cap, use a key cap puller in the same orientation as with fingers.
    Ask FixBot
  3. NPET K10V3 Membrane Replacement, Membrane: step 3, image 1 of 1
    • Flip the keyboard over so the bottom is facing upwards.
    • Remove fifteen 4.5 mm screws using a Phillips #2 screwdriver.
    • Remove three 9 mm screws using a Phillips #2 screwdriver.
    • Remove the screws from the kickstand plate first followed by the remaining screws for removal of the backplate.
    Ask FixBot
  4. NPET K10V3 Membrane Replacement: step 4, image 1 of 2 NPET K10V3 Membrane Replacement: step 4, image 2 of 2
    • Remove the kickstand.
    • Remove the back plate.
    • Keep in mind the location of the USB cable to ensure it is not damaged when re-assembling.
    Ask FixBot
  5. NPET K10V3 Membrane Replacement: step 5, image 1 of 2 NPET K10V3 Membrane Replacement: step 5, image 2 of 2
    • Remove the rubber gasket that compresses the connections.
    • When removing the gasket, lift straight upward to avoid damage and snagging.
    • Clean the gasket if there is any dirt or debris.
    • Do not use chemicals or liquids when cleaning to avoid damage.
    Ask FixBot
  6. NPET K10V3 Membrane Replacement: step 6, image 1 of 2 NPET K10V3 Membrane Replacement: step 6, image 2 of 2
    • Remove the membrane gently to reveal the copper connections for both motherboard and membrane.
    • Remove the motherboard from the membrane.
    • Remove the membrane out with the motherboard.
    • When removing both parts, lift straight upward to avoid damage and snagging.
    Ask FixBot
  7. NPET K10V3 Membrane Replacement: step 7, image 1 of 1
    • Place the membrane with the motherboard on a clean surface.
    • If the membrane is dirty around the key gaskets, clean gently without chemicals or liquids.
    Ask FixBot
Matthew Costa
343 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 37
All Time: 541
