NETGEAR WGT624 v3 Reset Button Replacement
    1. NETGEAR WGT624 v3 Reset Button Replacement, Lower Case: step 1, image 1 of 1
      • Turn the device so that the bottom is facing up.
      Ask FixBot
    2. NETGEAR WGT624 v3 Reset Button Replacement: step 2, image 1 of 3 NETGEAR WGT624 v3 Reset Button Replacement: step 2, image 2 of 3 NETGEAR WGT624 v3 Reset Button Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to carefully lift the rubber stops in each corner.
      • Do not completely remove the rubber stops, because they are difficult to replace.
      Ask FixBot
    3. NETGEAR WGT624 v3 Reset Button Replacement: step 3, image 1 of 2 NETGEAR WGT624 v3 Reset Button Replacement: step 3, image 2 of 2
      • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
      Ask FixBot
    4. NETGEAR WGT624 v3 Reset Button Replacement: step 4, image 1 of 2 NETGEAR WGT624 v3 Reset Button Replacement: step 4, image 2 of 2
      • Lift the lower case straight up from the rest of the router.
      Ask FixBot
    1. NETGEAR WGT624 v3 Reset Button Replacement, Motherboard: step 5, image 1 of 2 NETGEAR WGT624 v3 Reset Button Replacement, Motherboard: step 5, image 2 of 2
      • Remove the clear plastic casing by lifting it straight up from the router.
      Ask FixBot
    2. NETGEAR WGT624 v3 Reset Button Replacement: step 6, image 1 of 2 NETGEAR WGT624 v3 Reset Button Replacement: step 6, image 2 of 2
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Ask FixBot
    1. NETGEAR WGT624 v3 Reset Button Replacement, Antenna: step 7, image 1 of 1
      • Turn the motherboard, so that the top is facing upwards.
      • Place the motherboard on a clean flat surface.
      Ask FixBot
    2. NETGEAR WGT624 v3 Reset Button Replacement: step 8, image 1 of 2 NETGEAR WGT624 v3 Reset Button Replacement: step 8, image 2 of 2
      • Remove the yellow tape that holds the wire.
      • Make sure that you set the tape aside on a clean surface, so that it can be reused.
      Ask FixBot
    3. NETGEAR WGT624 v3 Reset Button Replacement: step 9, image 1 of 3 NETGEAR WGT624 v3 Reset Button Replacement: step 9, image 2 of 3 NETGEAR WGT624 v3 Reset Button Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
      • The wire should now be completely separate from the motherboard.
      Ask FixBot
    4. NETGEAR WGT624 v3 Reset Button Replacement: step 10, image 1 of 1
      • Extend the antenna away from the device, so that it becomes straight.
      Ask FixBot
    5. NETGEAR WGT624 v3 Reset Button Replacement: step 11, image 1 of 3 NETGEAR WGT624 v3 Reset Button Replacement: step 11, image 2 of 3 NETGEAR WGT624 v3 Reset Button Replacement: step 11, image 3 of 3
      • Find the clips that hold the antenna onto the router.
      • Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
      • The antenna may take considerable force to remove.
      Ask FixBot
    6. NETGEAR WGT624 v3 Reset Button Replacement: step 12, image 1 of 1
      • Completely separate the antenna and wire from the rest of the device.
      Ask FixBot
    1. NETGEAR WGT624 v3 Reset Button Replacement, Reset Button: step 13, image 1 of 2 NETGEAR WGT624 v3 Reset Button Replacement, Reset Button: step 13, image 2 of 2
      • Remove the metal frame.
      Ask FixBot
    2. NETGEAR WGT624 v3 Reset Button Replacement: step 14, image 1 of 1
      • Turn over the motherboard.
      Ask FixBot
    3. NETGEAR WGT624 v3 Reset Button Replacement: step 15, image 1 of 1
      • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
      • Desolder the four connections between the reset button and the motherboard
      • For proper soldering and desoldering techniques, refer here.
      • Pull the reset button from the other side of the mother board once the solder is liquid.
      Ask FixBot
Jonathon Sather
45 Reputation
3 Guides authored
Cal Poly, Team 3-31, Amido Winter 2013 Member of Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,174
