NETGEAR WGT624 v3 Motherboard Replacement
    1. NETGEAR WGT624 v3 Motherboard Replacement, Lower Case: step 1, image 1 of 1
      • Turn the device so that the bottom is facing up.
      Ask FixBot
    2. NETGEAR WGT624 v3 Motherboard Replacement: step 2, image 1 of 3 NETGEAR WGT624 v3 Motherboard Replacement: step 2, image 2 of 3 NETGEAR WGT624 v3 Motherboard Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to carefully lift the rubber stops in each corner.
      • Do not completely remove the rubber stops, because they are difficult to replace.
      Ask FixBot
    3. NETGEAR WGT624 v3 Motherboard Replacement: step 3, image 1 of 2 NETGEAR WGT624 v3 Motherboard Replacement: step 3, image 2 of 2
      • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
      Ask FixBot
    4. NETGEAR WGT624 v3 Motherboard Replacement: step 4, image 1 of 2 NETGEAR WGT624 v3 Motherboard Replacement: step 4, image 2 of 2
      • Lift the lower case straight up from the rest of the router.
      Ask FixBot
    1. NETGEAR WGT624 v3 Motherboard Replacement, Motherboard: step 5, image 1 of 2 NETGEAR WGT624 v3 Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Remove the clear plastic casing by lifting it straight up from the router.
      Ask FixBot
    2. NETGEAR WGT624 v3 Motherboard Replacement: step 6, image 1 of 2 NETGEAR WGT624 v3 Motherboard Replacement: step 6, image 2 of 2
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Ask FixBot
Corey Worthington
50 Reputation
1 Guide authored
Cal Poly, Team 3-31, Amido Winter 2013 Member of Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 839
