NERF Doomlands 2169 Lawbringer Blaster Spring Replacement
  1. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: step 1, image 1 of 2 NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: step 1, image 2 of 2
    • Remove sixteen screws from the outer case.
    • Remove the outer case from the rest of the device.
    Ask FixBot
  2. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 2, image 1 of 1
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Potential for device damage: Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out!
    Ask FixBot
  3. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 3, image 1 of 1
    • Remove the exterior spring from the sliding mechanism and rotate the gun to the opposite side.
    Ask FixBot
  4. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 4, image 1 of 2 NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 4, image 2 of 2
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
    Ask FixBot
  5. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 5, image 1 of 1
    • Remove the spring and trigger mechanism from the gun and set aside.
    Ask FixBot
  6. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 6, image 1 of 1
    • Carefully slide out the big spring and fit in your replacement (the thin-coil end is coiled around the orange plastic).
    • Potential for device damage: This is where the spring load mechanism is located. Be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
    Ask FixBot
  7. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 7, image 1 of 1
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
    • Make sure the orange slide is above the spring. A second set of hands would be useful during this step.
    Ask FixBot
  8. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 8, image 1 of 1
    • Reconnect the spring to the orange slider and connect the orange slider to the grey hook.
    Ask FixBot
  9. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 9, image 1 of 1
    • Slide the orange supporting piece into the crevice below the air chamber.
    Ask FixBot
  10. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 10, image 1 of 1
    • Slide the rotating cartridge back into place.
    Ask FixBot
  11. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 11, image 1 of 1
    • Carefully reassemble the NERF Lawbringer in the same order you took it apart. Carefully reattach the three screws that seal the air chamber.
    Ask FixBot
  12. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: step 12, image 1 of 1
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
    Ask FixBot
Finish Line
Georgia Slack
113 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,291
