NABI XD Motherboard Replacement
    1. NABI XD Motherboard Replacement, Rear panel: step 1, image 1 of 2 NABI XD Motherboard Replacement, Rear panel: step 1, image 2 of 2
      • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
      Ask FixBot
    2. NABI XD Motherboard Replacement: step 2, image 1 of 1
      • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
      • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
      • Go around the NABI XD and separate the rear panel from the device.
      Ask FixBot
    1. NABI XD Motherboard Replacement, Battery: step 3, image 1 of 2 NABI XD Motherboard Replacement, Battery: step 3, image 2 of 2
      • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
      Ask FixBot
    2. NABI XD Motherboard Replacement: step 4, image 1 of 1
      • Battery is glued to the base, lift carefully.
      • To remove battery, lift the battery up from the motherboard.
      Ask FixBot
    1. NABI XD Motherboard Replacement, Charging port: step 5, image 1 of 2 NABI XD Motherboard Replacement, Charging port: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
      • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
      Ask FixBot
    2. NABI XD Motherboard Replacement: step 6, image 1 of 1
      • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
      • Lift the charging port from the NABI XD.
      Ask FixBot
    1. NABI XD Motherboard Replacement, Motherboard: step 7, image 1 of 3 NABI XD Motherboard Replacement, Motherboard: step 7, image 2 of 3 NABI XD Motherboard Replacement, Motherboard: step 7, image 3 of 3
      Buy
      • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
      • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
      • You need to remove 4 ribbons
      Ask FixBot
    2. NABI XD Motherboard Replacement: step 8, image 1 of 3 NABI XD Motherboard Replacement: step 8, image 2 of 3 NABI XD Motherboard Replacement: step 8, image 3 of 3
      • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
      • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
      Ask FixBot
    3. NABI XD Motherboard Replacement: step 9, image 1 of 2 NABI XD Motherboard Replacement: step 9, image 2 of 2
      • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
      Ask FixBot
    4. NABI XD Motherboard Replacement: step 10, image 1 of 2 NABI XD Motherboard Replacement: step 10, image 2 of 2
      • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
      Ask FixBot
    5. NABI XD Motherboard Replacement: step 11, image 1 of 1
      • Lift the motherboard up away from the Nabi XD.
      Ask FixBot
Marissa Schiereck
638 Reputation
6 Guides authored
USF Tampa, Team 17-2, Blackwell Fall 2016 Member of USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Members
72 Guides authored
1 Guide Comment
Donde puedo conprar la pelicula de la tables o el displey y tatil
maria-201309 - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 625
