Up to 20% off select tools
NABI XD Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
80
All Time:
1,434
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Has the battery been damaged or the device won't charge. Changing the battery may fix these problems.
    1. NABI XD Battery Replacement, Rear panel: step 1, image 1 of 2 NABI XD Battery Replacement, Rear panel: step 1, image 2 of 2
      • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
      Ask FixBot
    2. NABI XD Battery Replacement: step 2, image 1 of 1
      • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
      • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
      • Go around the NABI XD and separate the rear panel from the device.
      Ask FixBot
    1. NABI XD Battery Replacement, Battery: step 3, image 1 of 2 NABI XD Battery Replacement, Battery: step 3, image 2 of 2
      • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
      Ask FixBot
    2. NABI XD Battery Replacement: step 4, image 1 of 1
      • Battery is glued to the base, lift carefully.
      • To remove battery, lift the battery up from the motherboard.
      Ask FixBot
Author
with
Marissa Schiereck
638 Reputation
6 Guides authored
USF Tampa, Team 17-2, Blackwell Fall 2016 Member of USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Members
72 Guides authored
1 Guide Comment
Where can you get the battery?
Dave - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 80
All Time: 1,434
