N-Strike Nite Finder EX-3 Battery Replacement
    1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: step 1, image 1 of 1
      • The batteries are located in the handle of the blaster.
      • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
      Ask FixBot
    2. N-Strike Nite Finder EX-3 Battery Replacement: step 2, image 1 of 1
      • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
      • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
      Ask FixBot
Nicholas Samokyszyn
359 Reputation
3 Guides authored
Michigan Tech, Team 5-8, Lauer Spring 2014 Member of Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 99
All Time: 3,337
