Up to 20% off select tools
MyFirst Camera Insta 2 teardown
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
115
All Time:
1,551
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Teardown for polaroid-like toy
    1. MyFirst Camera Insta 2 teardown, Prepare teardown: step 1, image 1 of 3 MyFirst Camera Insta 2 teardown, Prepare teardown: step 1, image 2 of 3 MyFirst Camera Insta 2 teardown, Prepare teardown: step 1, image 3 of 3
      • Remove SD card, carry strap and paper cartridge
      Ask FixBot
    2. MyFirst Camera Insta 2 teardown, Lift the front panel: step 2, image 1 of 2 MyFirst Camera Insta 2 teardown, Lift the front panel: step 2, image 2 of 2
      • Remove the front panel
      • The panel is simply clipped and can be declipped easily by using a mediator as lever
      Ask FixBot
    3. MyFirst Camera Insta 2 teardown, Unscrew front panel: step 3, image 1 of 2 MyFirst Camera Insta 2 teardown, Unscrew front panel: step 3, image 2 of 2
      • The toy is closed by 5 Philips-head screws, size 0
      • Unscrew them all and open the product
      Ask FixBot
    4. MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: step 4, image 1 of 3 MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: step 4, image 2 of 3 MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: step 4, image 3 of 3
      • The white piece is held by 4 Philips-head screws
      • Unscrew the three screws you can already access
      • Unscrew the selfie camera, held by two smaller screws
      • Under the camera, unscrew the forth screw holding the piece
      Ask FixBot
    5. MyFirst Camera Insta 2 teardown, Disconnect the screen: step 5, image 1 of 1
      • Remove the glue around the screen connector
      • Disconnect by lifting the connector clip upward
      Ask FixBot
    6. MyFirst Camera Insta 2 teardown, Unscrew the PCB: step 6, image 1 of 2 MyFirst Camera Insta 2 teardown, Unscrew the PCB: step 6, image 2 of 2
      • The board is held by the 4 previously removed screws, plus another screw close to USB connector
      • Once all those are removed and the screen is disconnected, pull the card from its compartment by sliding it on the side opposite to USB connector
      Ask FixBot
    7. MyFirst Camera Insta 2 teardown, Teardown view: step 7, image 1 of 3 MyFirst Camera Insta 2 teardown, Teardown view: step 7, image 2 of 3 MyFirst Camera Insta 2 teardown, Teardown view: step 7, image 3 of 3
      • Unknown microcontrolleur, QFP80 package , with reference "2104G-91"
      • Princeton Technology PT5139-HT motor driver
      • Syncrown PT48D 2-inch thermal printer
      • Thinksum 123050 7.4V 750mAh li-ion battery
      • Screen, speaker, two photo modules
      Ask FixBot
To reassemble your device, follow the unmounting instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Eve Redero
3,414 Reputation
11 Guides authored
1 Guide Comment
Hi,
Where can I purchase a replacement lcd screen for the “myfirst camera insta 2” model no. FC2401
Christian Juul Henriksen - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 115
All Time: 1,551
