Up to 20% off select tools
Munchkinz Volume Button assembly
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
87
All Time:
814
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your volume buttons are not working properly follow this guide to replace them.
    1. Munchkinz Volume Button assembly, Opening Device: step 1, image 1 of 1
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Ask FixBot
    2. Munchkinz Volume Button assembly, Pry Device Apart: step 2, image 1 of 2 Munchkinz Volume Button assembly, Pry Device Apart: step 2, image 2 of 2
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Ask FixBot
    3. Munchkinz Volume Button assembly, Separated Device: step 3, image 1 of 1
      • After prying the device apart, it should look like this.
      Ask FixBot
    1. Munchkinz Volume Button assembly, Pry Camera: step 4, image 1 of 1
      • Use the slim plastic opening tool to pry the camera from its initial position.
      Ask FixBot
    2. Munchkinz Volume Button assembly, Disconnect Ribbon: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
      Ask FixBot
    1. Munchkinz Volume Button assembly, Volume Button: step 6, image 1 of 1
      • Remove the plastic volume button.
      Ask FixBot
    2. Munchkinz Volume Button assembly, Unscrew Module: step 7, image 1 of 1
      • Remove the two screws that hold the volume button assembly in place.
      Ask FixBot
    3. Munchkinz Volume Button assembly, Solder Module Wires: step 8, image 1 of 1
      • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
      Ask FixBot
Author
with
David Wood
440 Reputation
4 Guides authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 87
All Time: 814
