Up to 20% off select tools
Munchkinz LCD Assembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
97
All Time:
951
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
Introduction
Go to step 1 ↓
If your screen is not working properly follow this guide to replace it.
    1. Munchkinz LCD Assembly, Opening Device: step 1, image 1 of 1
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Ask FixBot
    2. Munchkinz LCD Assembly, Pry Device Apart: step 2, image 1 of 2 Munchkinz LCD Assembly, Pry Device Apart: step 2, image 2 of 2
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Ask FixBot
    3. Munchkinz LCD Assembly, Separated Device: step 3, image 1 of 1
      • After prying the device apart, it should look like this.
      Ask FixBot
    1. Munchkinz LCD Assembly, Remove Speaker: step 4, image 1 of 1
      • Use the plastic opening tool to remove the speaker from the casing.
      Ask FixBot
    2. Munchkinz LCD Assembly, Pry Camera: step 5, image 1 of 1
      • Use the slim plastic opening tool to pry the camera from its position.
      Ask FixBot
    3. Munchkinz LCD Assembly, Unscrew Volume Module: step 6, image 1 of 2 Munchkinz LCD Assembly, Unscrew Volume Module: step 6, image 2 of 2
      • Unscrew the two screws that hold the volume module to the casing.
      Ask FixBot
    4. Munchkinz LCD Assembly, Pry Battery: step 7, image 1 of 1
      • Use the plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      Ask FixBot
    5. Munchkinz LCD Assembly, Remove Ribbons: step 8, image 1 of 1
      • Remove the two highlighted ribbons from the motherboard.
      Ask FixBot
    6. Munchkinz LCD Assembly, Remove Screws: step 9, image 1 of 1
      • Use the screw driver to remove the highlighted screws.
      Ask FixBot
    7. Munchkinz LCD Assembly, Remove Hidden Screw: step 10, image 1 of 1
      • Use the plastic opening tool to hold the camera ribbon back.
      • Unscrew the screw under ribbon with the screw driver.
      Ask FixBot
    8. Munchkinz LCD Assembly, Remove Motherboard: step 11, image 1 of 1
      • Remove the motherboard from the casing.
      Ask FixBot
    9. Munchkinz LCD Assembly, Pry Up Screen: step 12, image 1 of 3 Munchkinz LCD Assembly, Pry Up Screen: step 12, image 2 of 3 Munchkinz LCD Assembly, Pry Up Screen: step 12, image 3 of 3
      • Oriented the device so the battery is closest to the user.
      • Use the plastic opening tool to pry the clips up to release LCD screen.
      • Gently lift the northern end of the screen and slide it out horizontally.
      Ask FixBot
    10. Munchkinz LCD Assembly, Solder LCD Wires: step 13, image 1 of 1
      • Unsolder the black and red LCD wires.
      Ask FixBot
Author
with
David Wood
440 Reputation
4 Guides authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 97
All Time: 951
