Up to 20% off select tools
Munchkinz Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
83
All Time:
682
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
  • iFixit Opening Tool
    4.8
  • Tweezers
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If the camera is not working correctly follow this guide to replace it.
    1. Munchkinz Camera Replacement, Opening Device: step 1, image 1 of 1
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Ask FixBot
    2. Munchkinz Camera Replacement, Pry Device Apart: step 2, image 1 of 2 Munchkinz Camera Replacement, Pry Device Apart: step 2, image 2 of 2
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Ask FixBot
    3. Munchkinz Camera Replacement, Separated Device: step 3, image 1 of 1
      • After prying the device apart, it should look like this.
      Ask FixBot
    1. Munchkinz Camera Replacement, Pry Camera: step 4, image 1 of 1
      • Use the slim plastic opening tool to pry the camera from its initial position.
      Ask FixBot
    2. Munchkinz Camera Replacement, Disconnect Ribbon: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
      Ask FixBot
Author
with
David Wood
440 Reputation
4 Guides authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 682
