Up to 20% off select tools
Munchkinz Battery Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
87
All Time:
1,035
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Display how to remove the battery.
    1. Munchkinz Battery Replacement, Opening Device: step 1, image 1 of 1
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Ask FixBot
    2. Munchkinz Battery Replacement, Pry Device Apart: step 2, image 1 of 2 Munchkinz Battery Replacement, Pry Device Apart: step 2, image 2 of 2
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Ask FixBot
    3. Munchkinz Battery Replacement, Separated Device: step 3, image 1 of 1
      • After prying the device apart, it should look like this.
      Ask FixBot
    1. Munchkinz Battery Replacement, Removing battery: step 4, image 1 of 3 Munchkinz Battery Replacement, Removing battery: step 4, image 2 of 3 Munchkinz Battery Replacement, Removing battery: step 4, image 3 of 3
      • Use the wide plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      Ask FixBot
    2. Munchkinz Battery Replacement, Remove battery completely: step 5, image 1 of 1
      • Use the Soldering Iron to disconnect the each cable.
      Ask FixBot
Author
with
Hee Jin Cho
113 Reputation
1 Guide authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 87
All Time: 1,035
