Munchkin Mozart Magic Cube Light Replacement
  1. Munchkin Mozart Magic Cube Light Replacement, Face plate: step 1, image 1 of 2 Munchkin Mozart Magic Cube Light Replacement, Face plate: step 1, image 2 of 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
    Ask FixBot
  2. Munchkin Mozart Magic Cube Light Replacement: step 2, image 1 of 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
    Ask FixBot
  3. Munchkin Mozart Magic Cube Light Replacement: step 3, image 1 of 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
    Ask FixBot
  4. Munchkin Mozart Magic Cube Light Replacement: step 4, image 1 of 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
    Ask FixBot
  5. Munchkin Mozart Magic Cube Light Replacement: step 5, image 1 of 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
    Ask FixBot
  6. Munchkin Mozart Magic Cube Light Replacement: step 6, image 1 of 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
    Ask FixBot
  7. Munchkin Mozart Magic Cube Light Replacement: step 7, image 1 of 1
    • Remove the rubber corners by simply pulling them off.
    Ask FixBot
  8. Munchkin Mozart Magic Cube Light Replacement, Frame Removal: step 8, image 1 of 1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
    Ask FixBot
  9. Munchkin Mozart Magic Cube Light Replacement, Light: step 9, image 1 of 1
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
    • Use the Jimmy to remove the glue connecting the motherboard to the white frame.
    Ask FixBot
  10. Munchkin Mozart Magic Cube Light Replacement: step 10, image 1 of 1
    • Slide the motherboard out of the frame.
    Ask FixBot
  11. Munchkin Mozart Magic Cube Light Replacement: step 11, image 1 of 1
    • Use the soldering iron to desolder the LED by applying heat to the half sphere like connections.
    • For soldering instructions please see this additional guide How To Solder and Desolder Connections
    Ask FixBot
  12. Munchkin Mozart Magic Cube Light Replacement: step 12, image 1 of 1
    • Take the new LED and solder the two legs back to the motherboard.
    Ask FixBot
Nikolas Soulandros
291 Reputation
2 Guides authored
USF Tampa, Team 1-4, Sullivan Fall 2015 Member of USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 37
All Time: 831
