Munchkin Mozart Magic Cube Frame Removal Replacement
  1. Munchkin Mozart Magic Cube Frame Removal Replacement, Face plate: step 1, image 1 of 2 Munchkin Mozart Magic Cube Frame Removal Replacement, Face plate: step 1, image 2 of 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
    Ask FixBot
  2. Munchkin Mozart Magic Cube Frame Removal Replacement: step 2, image 1 of 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
    Ask FixBot
  3. Munchkin Mozart Magic Cube Frame Removal Replacement: step 3, image 1 of 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
    Ask FixBot
  4. Munchkin Mozart Magic Cube Frame Removal Replacement: step 4, image 1 of 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
    Ask FixBot
  5. Munchkin Mozart Magic Cube Frame Removal Replacement: step 5, image 1 of 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
    Ask FixBot
  6. Munchkin Mozart Magic Cube Frame Removal Replacement: step 6, image 1 of 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
    Ask FixBot
  7. Munchkin Mozart Magic Cube Frame Removal Replacement: step 7, image 1 of 1
    • Remove the rubber corners by simply pulling them off.
    Ask FixBot
  8. Munchkin Mozart Magic Cube Frame Removal Replacement, Frame Removal: step 8, image 1 of 1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
    Ask FixBot
Ibrahim Aldairem
335 Reputation
2 Guides authored
USF Tampa, Team 1-4, Sullivan Fall 2015 Member of USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 53
All Time: 2,235
