Mt. Fury Roadmaster Pedal Replacement
  1. Mt. Fury Roadmaster Pedal Replacement, Pedal: step 1, image 1 of 1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
    Ask FixBot
  2. Mt. Fury Roadmaster Pedal Replacement: step 2, image 1 of 3 Mt. Fury Roadmaster Pedal Replacement: step 2, image 2 of 3 Mt. Fury Roadmaster Pedal Replacement: step 2, image 3 of 3
    • Locate the 15mm pedal nut, and position the crank arms for maximum leverage.
    • Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm.
    • A considerable amount of force may be required to break pedal nut free.
    Ask FixBot
To install new pedal, follow these instructions in reverse order.
Samantha Rawlins
476 Reputation
3 Guides authored
Cal Poly, Team 1-40, Maness Winter 2014 Member of Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 37
All Time: 2,851
