Mr. Coffee DW13 Tubing Replacement
  1. Mr. Coffee DW13 Tubing Replacement, Base: step 1, image 1 of 2 Mr. Coffee DW13 Tubing Replacement, Base: step 1, image 2 of 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
    Ask FixBot
  2. Mr. Coffee DW13 Tubing Replacement: step 2, image 1 of 2 Mr. Coffee DW13 Tubing Replacement: step 2, image 2 of 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
    Ask FixBot
  3. Mr. Coffee DW13 Tubing Replacement: step 3, image 1 of 1
    • Gently lift the base cover to expose the inside of the coffee machine.
    Ask FixBot
  4. Mr. Coffee DW13 Tubing Replacement, Tubing: step 4, image 1 of 2 Mr. Coffee DW13 Tubing Replacement, Tubing: step 4, image 2 of 2
    • Identify and remove the two 13mm screws securing the silver support bracket using a phillips head screw driver.
    Ask FixBot
  5. Mr. Coffee DW13 Tubing Replacement: step 5, image 1 of 1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
    Ask FixBot
  6. Mr. Coffee DW13 Tubing Replacement: step 6, image 1 of 2 Mr. Coffee DW13 Tubing Replacement: step 6, image 2 of 2
    • Use pliers to pinch and loosen the crimps.
    Ask FixBot
  7. Mr. Coffee DW13 Tubing Replacement: step 7, image 1 of 1
    • Once the crimps are loosened, slide them down the tubing.
    Ask FixBot
  8. Mr. Coffee DW13 Tubing Replacement: step 8, image 1 of 2 Mr. Coffee DW13 Tubing Replacement: step 8, image 2 of 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
    Ask FixBot
  9. Mr. Coffee DW13 Tubing Replacement: step 9, image 1 of 3 Mr. Coffee DW13 Tubing Replacement: step 9, image 2 of 3 Mr. Coffee DW13 Tubing Replacement: step 9, image 3 of 3
    • Gently pull on plastic tubing, freeing it from the coffee maker
    • One of the tubes has a red ball check valve in the middle. Be sure to note which hole it connects to.
    Ask FixBot
3 other people completed this guide.
Kinsie Ward
228 Reputation
1 Guide authored
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Members
13 Guides authored
8 Guide Comments
Great photos. I've done this on another mr coffee model twice. Once for lime buildup, once for a coffee ground clogging it. Make sure you are gentle with the soft tubing. I split the hose at one end. The clamps now barely covers the split, but I'm looking for a replacement tube and ball valve.
markvassmer - Reply Share
I did not have to detach the heating coil from the plate in order to remove the tubing.
I found that the check valve was clogged with debris on my unit. Blowing it out cleared the clog. My unit's check valve is built into the tube that goes from the reservoir to the coil, so I only had to remove that tube to solve my issue.
rulegit2000 - Reply Share
Where does the tube with the check valve attach?
latimert36@windstream.net
Thomas Latimer - Reply Share
Water inlet tube from the tank on my model Mr. Coffee BVMC-SJX33GT.
Mark Vassmer - Reply Share
MarkVassmer -- did you find a replacement tube and ball valve? If so, where?
jay_amor - Reply Share
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 46
All Time: 8,608
