Mr. Coffee DW13 O Ring Replacement
  1. Mr. Coffee DW13 O Ring Replacement, Base: step 1, image 1 of 2 Mr. Coffee DW13 O Ring Replacement, Base: step 1, image 2 of 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
    Ask FixBot
  2. Mr. Coffee DW13 O Ring Replacement: step 2, image 1 of 2 Mr. Coffee DW13 O Ring Replacement: step 2, image 2 of 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
    Ask FixBot
  3. Mr. Coffee DW13 O Ring Replacement: step 3, image 1 of 1
    • Gently lift the base cover to expose the inside of the coffee machine.
    Ask FixBot
  4. Mr. Coffee DW13 O Ring Replacement, O Ring: step 4, image 1 of 2 Mr. Coffee DW13 O Ring Replacement, O Ring: step 4, image 2 of 2
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
    Ask FixBot
  5. Mr. Coffee DW13 O Ring Replacement: step 5, image 1 of 1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
    Ask FixBot
  6. Mr. Coffee DW13 O Ring Replacement: step 6, image 1 of 2 Mr. Coffee DW13 O Ring Replacement: step 6, image 2 of 2
    • Use needle-nose pilers to pinch and loosen the crimps
    Ask FixBot
  7. Mr. Coffee DW13 O Ring Replacement: step 7, image 1 of 1
    • Once the crimps are loosened, slide them down the tubing.
    Ask FixBot
  8. Mr. Coffee DW13 O Ring Replacement: step 8, image 1 of 2 Mr. Coffee DW13 O Ring Replacement: step 8, image 2 of 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
    Ask FixBot
  9. Mr. Coffee DW13 O Ring Replacement: step 9, image 1 of 2 Mr. Coffee DW13 O Ring Replacement: step 9, image 2 of 2
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
    Ask FixBot
  10. Mr. Coffee DW13 O Ring Replacement: step 10, image 1 of 2 Mr. Coffee DW13 O Ring Replacement: step 10, image 2 of 2
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    Ask FixBot
3 other people completed this guide.
Madeline Landis
140 Reputation
1 Guide authored
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 55
All Time: 1,375
