Mr. Coffee DW13 Heating Plate Replacement
  1. Mr. Coffee DW13 Heating Plate Replacement, Base: step 1, image 1 of 2 Mr. Coffee DW13 Heating Plate Replacement, Base: step 1, image 2 of 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
    Ask FixBot
  2. Mr. Coffee DW13 Heating Plate Replacement: step 2, image 1 of 2 Mr. Coffee DW13 Heating Plate Replacement: step 2, image 2 of 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
    Ask FixBot
  3. Mr. Coffee DW13 Heating Plate Replacement: step 3, image 1 of 1
    • Gently lift the base cover to expose the inside of the coffee machine.
    Ask FixBot
  4. Mr. Coffee DW13 Heating Plate Replacement, Heating Plate: step 4, image 1 of 2 Mr. Coffee DW13 Heating Plate Replacement, Heating Plate: step 4, image 2 of 2
    • Using the Phillips Head #2 screwdriver, remove the two 13 mm screws that secure the silver support bracket.
    Ask FixBot
  5. Mr. Coffee DW13 Heating Plate Replacement: step 5, image 1 of 1
    • Gently lift the silver support bracket to free the heating plate from the heating coil.
    Ask FixBot
  6. Mr. Coffee DW13 Heating Plate Replacement: step 6, image 1 of 2 Mr. Coffee DW13 Heating Plate Replacement: step 6, image 2 of 2
    • Pinch and loosen the crimps with the needle-nose pliers.
    Ask FixBot
  7. Mr. Coffee DW13 Heating Plate Replacement: step 7, image 1 of 1
    • Once the crimps are loosened, slide them down the tubing.
    Ask FixBot
  8. Mr. Coffee DW13 Heating Plate Replacement: step 8, image 1 of 2 Mr. Coffee DW13 Heating Plate Replacement: step 8, image 2 of 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other. Gently pull them apart.
    Ask FixBot
  9. Mr. Coffee DW13 Heating Plate Replacement: step 9, image 1 of 2 Mr. Coffee DW13 Heating Plate Replacement: step 9, image 2 of 2
    • Place your hand on the front side of the heating plate and push towards the bottom of the coffee maker to pop the heating plate out of place.
    Ask FixBot
7 other people completed this guide.
Luke Kraemer
254 Reputation
1 Guide authored
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Members
13 Guides authored
6 Guide Comments
so where do you get a replacement heating element (Im looking for one for a FTX49)
John Baker - Reply Share
You're missing steps and including unnecessary steps in this instruction. As well, you don't give a source for replacement warming plates. You might want to consider a rewrite.
chase canadé - Reply Share
I made a substitute hot plate from some sheet metal that I bought at the hardware store, and now I’m back in action with my delicious coffee.
Why they manufacture these plates out of poorly protected mild steel is beyond me. No, actually it isn’t beyond me - using inexpensive, unsuitable components certainly increases their profits. These plates almost certainly cost them less than 1¢ each, which is far cheaper than the 2¢ they’d pay for a suitable, durable part.
Lance J - Reply Share
Before removing anything, do an in circuit resistance of those two small copper colored cylinders with a black end.
They are thermal fuses, and should have in circuit resistances close to zero.
Their placement is important, especially the one under the silver support bracket.
gdrgry34fsdf324 - Reply Share
Our plate rusted out and quit heating very effectively. Will try a new part?
Kathy Oliveira - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 51
All Time: 8,974
